- Joined
- Apr 14, 2004
- Threads
- 1,472
- Messages
- 36,800
- Location
- 818-953-9230
- Website
- www.marksoffroad.net
Be interested to see the shackle angles Aaron.
Thanks that means a lot. I know it isn't perfect but I'm glad others can appreciate it.I like what you're doing.
Thanks, I've slacked on updates for a little bit but I have a few more things I'll post. Like everyone else I love pictures.Great story and photos here. Good work!
I've put this project off for the time being because I may be back at work soon from this whole stay at home stuff. But it that changes, I may want to take advantage of doing this work.I need to do these rebuilds too. I have the kits (from Cruiser Outfitters), just waiting to get to that part of my build. Are there links to the videos? AA Ron - when you get to it, let me know, maybe we can work through it together.
I know exactly what you mean. I was sore just from lifting, moving, and shifting these things around by myself. Thanks for the props.I was sore for 3 or 4 days after replacing all my bushings, shackles, and pins. It’s a tough job to do alone! Nice work.
For sure. I took a couple pictures of how it sits now. I can say it rides really well and much better than my old stuff that was on there. Although that's not saying much from that really old man-a-fre lift that was on there.Be interested to see the shackle angles Aaron.
Also keep in mind most of not all will be done by myself.
Good idea. I already have all the gaskets, what else do I need to take into account?It would only be a rabbit hole if you let it go there. What ever you budget for the reseal job double it then you will be happy when your done and you have money left over.
Pulling the drivetrain to do a reseal is excessive. You can do the rear main and oil pan (don’t be afraid of using a lot of fipg) when you have the flywheel at the shop being resurfaced. Make sure the freeze plug behind the bellhousing isn’t leaking too. Then reinstall the clutch, trans and transfer. There’s a ton of room to work on the passenger side if you remove the battery and support. Sometimes, I’ll sit with a beer in hand and make a plan in my head for the next day. Driving a 40 is more fun than wrenching, especially in the summer.
- Ok so you don't think I need to pull the motor, but transmission/tc does need to come out is that right? I like the sound of that but was worried about space. you make a good point about sufficient space to work though.
- What is fipg?
- Do I need to have the flywheel resurfaced no matter what? I hadn't anticipated that.
- I'll check the freeze plug for leaks. thanks for the tip.
- True more fun driving but if you want it to be reliable, sometimes the wrenching might be necessary.
I was watching this video from JNH Classics (not sure if he's ever been on here but he does excellent work restoring various vehicles including a running FJ40 build) and he gave me the same thought of not pulling the bell housing, just the transmission.In my experience(might not work for everyone) Unless the freeze plug is leaking, the bellhousing doesn’t need to come off. It’s a little more of a pain in the neck to do the oil pan in the truck but less than pulling the drivetrain. If you are planning on doing a lift, the oil pan would be easier with the axle out of the way.
FIPG is form in place gasket. Toyota’s gasket sealer. It’s pretty wicked stuff.
Maybe one of the heavy hitters will chime in but you can probably get away with not resurfacing the flywheel if it doesn’t have any gouges or cracks. The one that I used on the 72 was in pretty bad shape. I am doing one now that I probably won’t do the flywheel.
Thanks it's been fun learning as I go. I am running 31" tires but by the looks of it I would think you could fit 33s if you wanted. I haven't gotten a straight on side shot but I'll try to do that here soon.I like what you’ve done! Keep up the “refresh”.
BTW , I’m considering the same lift for my truck. What size tires are you running? I’d love to see a straight on side shot.
The FIPG only goes in certain places. Like around the arches under the front and rear crank seals.I was watching this video from JNH Classics (not sure if he's ever been on here but he does excellent work restoring various vehicles including a running FJ40 build) and he gave me the same thought of not pulling the bell housing, just the transmission.
Do you use the FIPG along with the actual gasket or only in place of a gasket that you do not have? As far as I know I have all the gaskets, but so do I need to buy this stuff and apply it to the gaskets as I install?
I'll analyze the flywheel when I get to that and see what I need to do if anything.
Thanks again for the info. I'm glad I asked some questions before ripping into this thing.
I've thought about the reseal transmission and transfer case vs. having a shop rebuild it for me. I keep going back and forth in my head, that or do it myself. I also don't have endless $.It's a good time to reseal or refresh the transmission and transfer case. It all depends on the condition of your flywheel but for about $100 bucks you can get it surfaced and be good to go. Also a good time to change the rear mounts and clean up the main grounds and starter and connections. You did a knuckle job so you should not have trouble with the rest.
JP
