With the videos from @orangefj45 and @OTRAMM, the right kit, FSM and the thread by @Vae Victus, you can rebuild the trans/transfer. You’ll have to take one set of bearings to a machine shop to be pressed off/on unless you have a shop press.Next on the list is going to be a new 2.5" HFS lift I ordered from CCOT. Not sure when it'll be here but I'm furloughed from work for a little while so I should have a little time to throw it on there.
I'll make sure to document the work and progress on here. I did do some research for lifts and felt like that was the one I wanted to use. Oddly enough there isn't a ton of HFS reviews on ih8mud, at least that I could find, I hope that's not a bad sign that I made a mistake. So my hope is to do a decently extensive write-up with pictures and progress for this lift for anyone who might be thinking of doing their own as well as height and ride, etc.
Stay tuned.
Question for anyone reading,
I have the lift, I have a engine gasket kit from Mark's Offroad @65swb45 (thanks Mark), I have some radiator hoses to replace, I have some motor mounts, and then if I keep going down the rabbit hole I would want to replace the clutch and possibly rebuild the transmission/tcase with new seals as well. In what order should I do these things that would make the most sense so I'm not taking off and putting things on over and over? Also is the engine/transmission/tcase a pretty huge job that I should get some expert help with or is my minimal learning skills good enough to dive into?
Replace the clutch, rear main seal and have the machine shop turn the flywheel.
30 year old Man-a-fre lift, hit me up.
