Builds A 60 Runs through it… (17 Viewers)
Just finished my FZJ80 rear axle swap last year. I ran custom brake lines using CuNi Alloy with the usual M10x1.0 fittings. Since I was doing all custom rear axle lines I put stainless gravel guard over the lines for protection.
The FZJ80 master cylinder has 2lb residual valves front and rear to keep the pads close to the rotors. If I would have figured this out a few weeks back I would have bought that over the 93 T100 MC which was cheaper. I plan on tearing out my LSPV and running the manual one mentioned.
I checked the build thread and it's pretty weak on tech info. pm me this evening after 4pm PST and I can text you a bunch of pictures.
Chevy 63" and FZJ80 FF Swamp
I wish I would have if I had known better at the time a few weeks ago since it has the residual valves built in. I am running a 93 T100 MC and booster.
yukon,
I have a spare semi-float rear axle sans diff already setup for SOA that no one wants for a very good deal. I visit mammoth area often in winter.
Thanksgiving I'll be passing through carson going north as well.
No, the adjustable valve goes in the rear brake circuit and cuts off a percentage of fluid flow to the rear brakes.
I wouldn’t run the factory 60 valve with the rear discs. You want to be able to adjust it.
Yes
There is this one which looks non adjustable.
Or this one which only says FJ40.
Thanks @cruisermatt
Any other parts would be appreciated. Got the pole barn bay cleaned out yesterday for next weekend. Was planning on some cutting but was on call for work and had 2 emergency no water calls.
Meet up with @Rustic76 and finally picked up his 4plus bumper. Got to tour his awesome cruiser collection. Thanks a lot buddy for the great deal on this. Hopefully we can go snow wheeling soon.
