400 in a 60?
State of Jefferson XX
Hi all, good to be active on site again! Sometimes life’s complicated! Going down the rabbit hole of engine swaps in oldgrey. And just to be contrary I was considering a ford 400 cause I have access to a sweet donor truck with 30,000 original miles on it that I can poach engine tranny etc. The truck is a f350 dump truck from a golf course. The trucks not worth working with but all the running gear is in great shape. I researched the threads and ran across one where Mace chimed in about his 5.0 in his 60 then a few post later the 400 was brought up but nothing specific as to dumping one in a 60. Other than my land cruisers I like old fords too. I can make this engine into a better torque monster easily than it already is and I think it would be a perfect match in my 87’ BUT, I can’t see a path to get there? Not sure if I would have to ditch all the LC stuff behind the engine? Bottomless pit of $$$$$$$ in fabrication, parts etc. Thought I would pose the question to the cruiser gods. What say you?
I personally wouldn't bother with it, just swap in a 6.0L LS and take advantage of all the aftermarket support here that makes it incredibly easy.
I've got a 5.3 in mine and can go 95+ on the highway, you don't need a 6.6L in these.
It’s not that I can’t go down the bow tie path, just was trying to think out of that box.
You’ve got my full support - don’t expect to be Toyota drive train and I have not heard of a Ford adapter kit buuuut
Who cares
Run Ford all the way to t case and bastard drive shafts
Remember the cardinal rule - their is no replacement for displacement
Oil on may be an issue but no one says you can’t make your own pan to fit
After 13 LS swaps - this sounds way fun and cool
Holler if you need any help or need to bounce ideas
