Build 76 Project Silver Back
Well I’ve been putting it off long enough. I think it’s time to cut my rear fender openings and install some Bushwacker flares. I think there’s no way around it due to the fact I’m running 35 x 12.5’s. Also, I will probably be installing 1/2” to 1” wheel spacers so flares are almost inevitable.
I know my rig is heavily modified, but there’s something about cutting on my rust free tub that makes me cringe.
What do you guys think? I’m still undecided if I like the look of the flares.
No Flares,
Flares
Skip the plastic cheapy flares and install longer bump stops.
Otherwise, show off more of your mad machining and fab skills and do something cool like integrating DOM tubing into the fenders and blending it in with the body and whatever rock sliders you may have.
You can always mount the flares without cutting the w/wells. If necessary do some surgery on the flares instead of the metal. Working with plastic or fiberglass is easier than what you did on that bumper. One thing for sure, whatever you do it will look great. :cheers:
  • Like
Reactions: SMG
Time for another update and a break from the rear bumper.
I was planning on holding off on the rear disc conversion until someone posted a thread with really nice pdf drawings of the rear disc.
I was able to take the PDF and covert it into a usable DXF file that can be used in my water jet at work. If anyone would like a copy I would be more than happy to share.
Tapping the holes for the caliper mounting bolts.
A little grinding on the calipers for clearance.
Test fit
I was able to cut off the backing plates with a Sawsall. No need to take out the axles.
Here’s some spacers made out of .125”
Test fitted the brackets. This will be the best position and will allow the calipier pins to pull out without any interference.
Here the PN for the disc. I purchased these from Advanced Auto. Keep in mind these are the non-heavy duty disc. The Heavy duty disc are to fat. Ask me how I know.
Here’s a picture boring out the centers to 4.180” My lathe isn’t big enough so I had to do it on my mill. Man did this suck! .050” cuts at a time took forever and it throws hot metal dust everywhere!
No Flares,
Flares
Is your rear axle in the s tock position? Or is it moved back? I would probably flex it out and go from their. I have a feeling you'll have to cut the fenders. U could cut the holes bigger but go flareless like @S4Cruiser did.
  • Like
Reactions: SMG
