What have you done to your Land Cruiser this week? (23 Viewers)
Rally next summer?
From last June.
Put the hard top back on and took the family for a couple beers. Well, not the kids, I don’t need anyone saying I’m a bad parent for letting them have a couple beers. They just split 1. View attachment 3451141
Tell daughter on the left in England that is not the peace sign. ;)
I had to look that up. She does have a little bow set….
No Pictures, but little things:
-> I found some debris in the prefilter for the diesel-pump (tiny glas-cup with a filter inside, used on the mercedes-engines)
I removed and cleaned it and found out, that there A LOT of debris, I guess from corrosion in the tank.
I changed the prefilter and the two normal fuel filters, both already a little bit dark. And I flushed the fuel tank. The old diesel was pretty dark/dirty.
Later I also found, that the tank only holds about 47Liters of diesel -> for a 4Liter-Engine :confused:
I most probably will change the tank to a plastic-Version with 55Liters, that's the maximum for the original position possible.
I've got an aluminium tank in mine under all the front seats, gives me about 120L.
Seen a few long range tanks around if you're willing to deviate from original.
@FJmaine not sure if you’re ever in northern Vt, Rt 58 off of 118 known as Hazen’s Notch. It’s closed from November thru May usually … great run towards Lowell.
these photos are from 1975.
