What Did You Do with Your 80 This Weekend? (21 Viewers)
Played around Slick Rock with a bunch of locals!
Are you on IG? That's where most of us chat and planned out this trip.
Just put your rear tire over it! But yeah it's a tight corner and that rock loves to catch your diff from all angles. It's a lot more chewed up now. This was last year going downhill
I do not have IG. :(
Agreed it was a lot more chewed up this year. Not sure I can get over that with my 35's LOL. well done sir!
These still available from overseas? Got part numbers ? Looks good
Yes they are. Only issue you will find is the rear most does not have the cut out for the running light.
Try Dave at Japan4x4.
Cheers
I was on 35s and went up the gauntlet with out issues
nice, I've been down it many times without "issue" just a 6 point turn lol
It does have a slight miss. The injectors were cleaned by a local Cruiser mechanic when he replaced the wire harness.
When you say leaking injector what do you mean?
There are times where it idles like there is a vacuum leak, but I think I found the issue related to that the oil cap was not screwed down tightly.
A leaking injector would allow fuel into the port/cylinder even when it is not supposed to, causing a rich cylinder. A vacuum leak would cause lean cylinder(s) so not likely to cause those numbers. If the printout has any of the other numbers like O2, CO2, or NOX, they can be entered into a Lambda Calculator to show just how rich (or lean) an engine is running. Do you have the tools to run a compression check?
I do not but I can probably borrow them from my boss. He at one point ran a garage in Tucson.
That is an insufficient EGR flow code, I'd be looking at that system, not the cats to start with.
I guess I should also post all the info, I was also getting a 0420 in conjunction. Thanks for the input. Also tested vsv and egr per FSM and replaced a ton of vacuum lines before getting to this point.
Went and shot my .300 win mag one last time before the elk hunt next weekend.
3 shots at 400 yards
3 shots at 500 yards
Target is a 6" circle
My buddy bailed on the hunt so I will be rolling solo for 9 days. Without a spotter 500 yards will be my max hunting shot but I am confident in the rifle, my hand loads, and my shooting ability out to 500.
Do you use a wind meter? Check out the Kestral 1000!
Nah, I'm not that hard-core into the long distance shooting thing. The stronger the wind the less distance I will be willing to shoot at an animal.
With my 210 gr bullets with a bc of .64 I can shoot out to 400 yards in heavy wind and still be in an 8" circel.
I like to use one when shooting long distance at the range but I don't carry one when hunting. You can only carry so much stuff. If the wind is high, and the shot is long I simply pass or try to get closer. I'll shoot 300 yards in low wind but any further and I'll probably pass. I only shoot a 154 grain bullet from a 7MM mag. It is a very fast round buy not very heavy.
  • Back
