There is some wild stuff going on with the roof of that house across the streetGot the DRLs working yesterday.. Looks pretty cool to me! Thanks: @Ironman 4x4 USA
Looks like a roof?There is some wild stuff going on with the roof of that house across the street
Brutal! That's one of the highest temps I've seen.It's days like this you apriciate the best engineering known to man, Toyota a/c vent under the steering wheel cooling the jatz crackers View attachment 2878784
NapaReplaced the tie rod ends with some 555s that the previous owner had purchased.
Discovered that a knuckle stud has been sheared off, and is broken inside of the knuckle (not the arms on the underside)
Anyone have tips for getting that stud out of a blind hole? Start drilling?
Going to source a 2 1/8" socket tomorrow to start taking apart the front knuckle on that side.
@Dusten I'm still in the "ownership in doubt" circle of hell with Wa dmv. I've spent more in mods and maintenance (prior to seats) than i paid for the rig, and can finally apply for title next week after 3 years. I'm still trying to figure out which office to write to regarding changing that bit of red tape. It has something to do with allowing previous owners to contest or something. In what world would you wait 3 years to rectify someone else getting ahold of a vehicle you own/owned?
Oh, the 80 series... I've brushed snow off of it a couple of times.
Sorry for the eye rolls and sighs in advance boys, I'm a triple checker.
Want to knock out the fluids tomorrow to start baselining and make sure I have everything I need the first time. After searching the forums and manual does the following look correct?
Fluids:
Engine Coolant: Ethylene-glycol antifreeze
T Case: 1.4 QT - SAE 75W-90 GL4/5
Trans: 1.7(?) QT - ATF DEXRON II/III
Diffs: Front no lock 2.5 + Rear no lock 2.9 QT - 80W-90
Power Steering: ATF DEX II/III
Brake: SAE J1703/FMVSS No. 116 DOT 3
Lube:
Wheel Bearing: Lithium base wheel bearing grease, NLGI No. 2
Steering knuckles: Molybdenum-disulfide lithium base chassis grease, NLGI No. 2
Propeller shafts: Lithium base wheel bearing grease, NLGI No. 2
First time doing any of this so I'll be relying on the forum and YT a lot lol. Thanks in advance.
Gotcha, it's auto. I'll look for that Toyota Red tomorrow. Planned on flushing just to start what I can fresh and have the feel goods about it.Coolant is Toyota red unless you're going to completely flush it.
Manual trans? Because if it's an automatic It's more like 5.5 quarts.
I am all for red coolant, but with these old rigs the best thing to do is stick with what you already have.I'll look for that Toyota Red tomorrow. Planned on flushing just to start what I can fresh and have the feel goods about it.
That's fair. I just assumed it was already red.I am all for red coolant, but with these old rigs the best thing to do is stick with what you already have.
In other words, if your rig has red coolant than stick with red. But if somebody has already switched to green than you might as well stick to green.
