What Did You Do with Your 80 This Weekend? (54 Viewers)
Had the crank seal replaced (no more oil leak!), did some interior rehab, installed a new stereo, then headed down to Big Bend for some desert camping.
I amazoned me up some assorted sized ferrite chokes to counteract the massive amount of RFI from my new Rigid D2s.
With loop as seen, works like a charm, back to normal that is. And my normal is no functional antenna, but a stubby in the hole.
Tight loop and as close to the light as possible seemed to be best. I tried several variations of loops, and tested on the weakest signal FM Station.
Without loop, did not work very welll.
So...add the loop, get close and you're good to go. Adding more chokes also not that effective. YMMV
The light above the D2 is a 100w Piaa halogen driving light. No RFI issues there.
Plugs, wires, cap, rotor, PCV valve/grommet/hoses.
It was time...
There is something wrong with your 80, it sure looks small next to the 100 series... I didn't think they were that much bigger.
My 80 is stock suspension and 285s. The 100 has AHC with ~2.5” lift running 295/70/18.
I was just giving you a hard time, your 80 looks good! I just didn't think the 100 was much bigger.
Santa Maria point on the Sea of Cortez
ZyX6N2nOBNgpxq7qaDkq4fAbCH6JCOBYEK06w27eLPuQ3Djh5mHs6Q_-neBhTMC-brVVY1rR-N12lePkDJNMTksWizu1SbwsmCVH75XC21X3G6dYs41a9NnH-B_Ylq-5Qhx4CC2mXHpY9UaRK-ksEbbTvSLFcWH1CCDXp9yHHqKEulYEC9BAjZp3XHrFmTvj17WV00Jwbuoz88aj6j2qPlr4vazOsNxcAhEy4y1oid4Pw17RWV49VSnRDmY1Jda1UU8G9CEXniSNgtlvXOdq3yVRqhqTf_C7OoXq6F3I0yADXNpd8Lp1bGi8l-ykPo1cwjPh_AhDdg4KYDxF6v8KwZA5gJaSqGPTfMNUgd5KxuYcTT4icS3f1jmUP1GrUePzxkFNepsg8-86tOHp-_14dtFynuOnseq8L0pbhdeGbNUFiY--5xPhov1XoVSlGYVaLs4y_pD-hxXydwE5eN25zVTwYEomqRnwoFjs6ybwlDIIG3dVaO6w8o4oThlvf7CYDE3jHd2Q4A-3XpcCqrus0fu01P6-q8IcMl-h0fiCJ6Wgt7Au89S8GdYNqWmNwP3YrMDWVOJoWs0lpFFOX93cAtqlvv_Ejn-BX_9s8pvo=w1194-h896-no
Our little private piece of paradise north of Gonzaga Bay - After a couple attempts it took 12PSI locked F&R to get there
aD4N5QGokSudMO4953pz8c4sqT0V6FkeDWTgc1gpyXsFzcTEiysCDPcAqgVCMY429PX6iy1Di5Ji8X37xOZSATZCpmqr5mM10uuU1Qu26dYcaHWHWkjsDAmHpCK4SHAz1UgTk9aa9vCyR2gRP8bcVpcMdmGU1dCi1IbtM03xbmeeQOnkwYm1JHN73e2wW7Km-dYmEzVsnLRKrbMaHgU78aEd6EHMdZjY0jGdzLAHpreUc3s5Yc2_B6kch4I025JIMvdgTZtewnt7PCMW9hSDAyqhoUhFpMgaYxp4WZZdFeOpbwYoDeWUpLlxNwwcwUDWMhNIQG4Y6hD-FFzezzMZ86J4VEagozxdOWM2vFZE_jXhPPeqER2p-6Vw0gizdJS21c1mn91Zhl-Phqiarlnmb4vd_BMWoCTpgsjB4wwnUSl9TdOblbrt2Gpy3XzJXK2rADdntmDk1G8qumQCgSx6Ls9P-lHGnPW87zfKaGntb29Vc8OleWWieQ-W971Vqaiy1gsd8mnMosNQ4f08T8xdsNwYKCjwaRKGDr3H5Odh9FRE3-f4jjhZ_sg6O43QyGD6cyW9xVLT6EpkLaM_V9UdpZj_s724FewScrL2s6rC=w1344-h896-no
The Pacific Ocean near Santa Rosaliita
SW9dtVKBd0SMo0FnWrm5gFQr5G1cEXwtlm7UQ-SiWWQ8xAXEBgAdahgvcs-aCAC_whjIYgBVCF5b2A3nYy0ZzhC8nxxTjV7yZf7C9ONRPL6xa0KB918UU3YF9RoeZ4IbnvKYLEx0XcXjMev8voEJML5rsnq9zcSobXH9bcVDSReTPHMfBYuVbopQp5d3VTqpf22JC_5OEx4iXMprJY5Bj9QK9pM0O3Zbs0PSyVlMf5M-gNcu08oAuF0KR1YRhbXVG88LRGvI6qgDsh3Exu07Vnvkx_1OZzT_1cm1yJ2Ieec7J0XRhewAAU_mhz8INxOfgUT64KGWqKYegbhTA_XXtghjEDXmGaqTHo0RBTL2SlkLmtluCo7lBfmUSlmGxvjo38GuvVBFE5ENpFC4L_pzmUKYayXbVU6tdQmK_fBwNFgMv11G9DoPpXp2AOerC_QgBRoYbWREU24klXgQlrnl8Wy6I7_j7_1gXdXllOCS5TnSyIrfsQvtiKISRMS5EKRat5d6ZeiMjxBh1bM7Tm39ilYvLAqLH4quWT-qURO7YXUkF84c_3LtfauHGRHSsV3R1S31oUVSPFUUAIPzmFrBB4baR4_IL_k5y7ejELE_=w1194-h896-no
What my LC looks like after 1499 miles of Baja:flipoff2:
M_0rtwgauEJtMDEJJiytfeaBTq6P7E2o-qIpFYSwDeCz-KP3oCa6GoqgDcBYa9zbDMdiagRMbOgFwANFbY2NI1CyXkIOl4MlR6ufpCxD8ecer7kdR3Ff09wB9eKtE50m0eLQosPl8tRz1dSSfmOoZxRQ3P64xobY2z4K-DW0dVePg6x0N9mmX13RO2vTglAD2JJ33AQqCeXOwaaQHyCnr8rfnzts2BZDyTVGYU9AVu-2odkbhLnd_gIJrPInuguzAfs8pRx-uDXGZGzi_SIyTQ2y4VSG1NA6n6ny8hdEdL5CweP3SOk8_lhtivKtnehK-m_bV0r_uE9Z1E_c1zxH0vuDQsGfoNH90z00hWkHMDFWkd3qvCUFIOg_sn2BGjmN4va0zOV3hu76sNtWOBHHr9cjeWGpgWiuDG5ub6RSmcqCqQXCBY3cYjLfpjglcUtYMduf5KXaLEehSRPO3q8klxIJ7KeGVp9TsNRNsBqD5c7SyC08j4LqI5qdmIyWnSD4HeKMZZqOjojX_v-4u4R1v9_D5hoTaYler8GD1zi_PFAM9Oa8muUPEfqLQMtgH0uh7r7VAAaoJJWX1ZYnQdcHipQ6Xdql0GNlz1px4sFk=w1194-h896-no
oh that is a great idea, what light did you use? its perfect.
Rigid Industries SRM, amber. They almost perfectly fit the end of the frame, so I made a bracket for them. My first welding project actually, and I used steel that was wayyy overkill for the job :). Not especially pretty, but it'll do.
sweet I was going to tack sheetmetal covers over those opening but this is perfect. I have to steal this idea Ill vary a tad.
@LandCruiserPhil Looks like a good time. Are you still headed south? My wife and I are heading down in 3 weeks to the tip for our yearly trip...
Will be back down to the Sea of Cortez in a couple weeks for Semana Santa then off to the Maze District with @Shoredreamer a couple days later. :steer::clap:
Note: Everything is paved from San Felipe to Bay of La except ~20 miles and I was able to average ~30mph on the dirt.
What did you do with your 80 this weekend: maintenance, fix, wheel, nothing, new mod??
Me:
Checked air in tires
Change oil&filter 180,000
Fill gas tank
Waiting on box of parts from Beno
Traded a 1987 SR5 4RUNNER straight across for our first 80.
So aside from an oil change and tune up, the entire family just...fell in love with our new ride.
  • Back
