What Did You Do with Your 80 This Weekend? (44 Viewers)
LMFAO!
They are a hard poly spacer but 20mm. My problem is the lip, on the bottom side, its too big for the spring to go around. Even lubed. So the spring Is tilted at the top a little. Its probably not the end of the world but its driving me crazy. I might try and cut the lip off, but that still leaves a cheap poly spacer up there. I should find metal solution.
Metal isn't necessarily better at 20mm, in fact the poly or rubber spacers provide a little extra vibration damping.
True, plenty of posting going on there.....
Keep posting Im still waiting for the count of bikinis owned:D and thanks for your likes on Instagram:cool:
37 owned.....but will be 38 as soon as @NLXTACY sends me one of his limited edition Wits' End bikini's that he's working on.
Finally. A Wits' End product that prevents overheating.
Installed this little camera...
Not spray but you definitely lather on the lube around the opening, I was right there behind you.
Wtf?!:confused:
Not to mention you're referring to Mr. AnalEcstasy himself.
I could tell y'all were buds, but I'm pretty sure @LS1FJ40 is about to be jealous.
Wtf?!:confused:
He had his turn. Chose to sleep on his stomach.
I was going to make a comment about a kitty cat but figured it would probably get deleted by the moral police...
