Not spray but you definitely lather on the lube around the opening, I was right there behind you.
Thats a rich fantasy life you live. I'm fairly certain it was @jtwopark
It broke pretty much flush with the flange's outer surface (closest to the radiator), so the hole is still filled with the stud remnant, but there's nothing sticking out, if that's what you're getting at.
They are a hard poly spacer but 20mm. My problem is the lip, on the bottom side, its too big for the spring to go around. Even lubed. So the spring Is tilted at the top a little. Its probably not the end of the world but its driving me crazy. I might try and cut the lip off, but that still leaves a cheap poly spacer up there. I should find metal solution.
True, plenty of posting going on there.....
37 owned.....but will be 38 as soon as @NLXTACY sends me one of his limited edition Wits' End bikini's that he's working on.Keep posting Im still waiting for the count of bikinis ownedand thanks for your likes on Instagram
Actually that will probably promote overheatingFinally. A Wits' End product that prevents overheating.
He will get overheated from running away.Not for Jose once he sees me in it![]()
It's worth as much as someone will pay for it! Amateur hour in here...Thats ok as long as nobody starts another "How much is my 80 worth" thread....lol
Wtf?!
Not to mention you're referring to Mr. AnalEcstasy himself.
I could tell y'all were buds, but I'm pretty sure @LS1FJ40 is about to be jealous.
Wtf?!
He had his turn. Chose to sleep on his stomach.
