What did you do on your 70 series today? (9 Viewers)
Nice, what was your method?
Just an orbital and some Maguiars ultimate compound.
Where did you get these flare seals??? They look great. I've been trying to find some this width and have been unsuccessful, mine are too skinny :shifty:.
PartSouq
5385190K0001
Those are the fronts. The rear seals are no longer produced, but I believe they're identical to the front in shape and dimension. Just shorter. I measured my fronts and they are about equal to both of the split rear seals. At least for the 77. So you can get away with 4 front seals to cover all 6 seals.
@c2dfj45 ….. “This one will find a home in a very special build”.
Well get to it. We need some excitement in the 70 Series section. 😊
Soon. Hopefully. So much work going on in the shop right now....my stuff is on the back burner :(
Pulled the cluster apart and cleaned all the contacts and electrical bits with contact cleaner gel and spray. My tachometer is now smooth and working.
I also found this gem. Do I have a 400 HP 1HZ tune or is this some gimmick?
are your door limiters popping due to some worn out or missing pins... does the noise drive you to distraction?! find yourself some good old cooter pins in a 6mm diameter and slide those suckers in for a pop-free experience!
find them at the local hardware supply of your choice. i found these in a drawer of hardware at work...
--r
Played in the mud with friends. 😁
a little corrosion abatement in the engine room.
no photo's from before. just some fasteners cleaned up, throttle bellcrank, spring catches on the air box. worked some of the chalkiness off of the crossover tube and intake plenum.
saving the wiring exploration for another night. might see if i can get the clock working yet tonight. firstly, checking fuses.
Interesting your radiator looks different than my 1HZ rig. did you replace it with something?
i have not. it's the same as when i picked it up last week. this is my first 1hz truck, and the radiator looks stock to me.
appears to be a Toyota radiator, the side brackets have been painted red at some point in it's life, possible that's throwing off the look?
--r
The FTE motor cleaned up really well. The block is really rusty....front cover faded....valve cover is chalky.....couple pieces on the trans rusted(some bolts, spacers). I'm guessing that this motor sat in the sun for a bit at some point....probably was never covered. Not a spec of grease or dirt anywhere on it(before we cleaned it obviously). Really curious about why so much rust on the block and so little paint. Weird.
View attachment 2711357View attachment 2711358View attachment 2711359
Another FTE band wagon … :lol: how quickly these engines spread like a virus…
Well, today it’s not about what I did, but rather what some other piece of s*** did. Pulling some crazy illegal move and clipping me in the process towards speeding off. Couldn’t get a plate number, and no way I could catch up to anything faster than a bicycle.
Anyone got a front LH fender? Ideally west coast. Partsouq has em pretty cheap but the shipping is more than the part.
With the cost of the flares being $$$$$, I’m contemplating just taking them off and selling the remaining three at a discount. I prefer the look without them, and was needing some paint/body work anyways, so I guess I’m glad this happened first.
Bummer. I've got a s***ty stock chrome bumper and a rusty fender...
Put some new mirrors on. Old ones looked okay, but had a vibration that bugged me.
  • Back
