Time is once again scarce, I just got back from a work trip that turned into two trips…. Unfortunately I was stuck in Hawaii for 10days …rough life. Didn’t see
@Aloha Jen & her 60 cruising around anywhere
I was able to come home for 24hrs and work on the cruiser before going straight into our family beach vacation this week.
I had left off with a leak in the A/C system & ordered parts.
The Engine is running great but has those 3 codes
P0651 (5V reference)
P0332 (knock sensor 2 bank 2 low input)
P0327 (knock sensor 1 bank 1 low input)
I took the multimeter through all the wiring harness checking for short, ground, continuity, checked the resistance on all the sensors…everything checks good. I bought another set of OEM knock sensors & pulled the intake off, swapped them out and investigated…
lots of info on LS1 tech about people buying knockoff or just bad parts, so I’m hopeful this makes it go away. The first set I bought were OEM, but I figured I’d try again.
I also bought new O2 sensors, I had mismatched used ones, so I figured now’s the time….so I dropped the Y-pipe to replace them, and dropped the inspection cover to look at the throw out bearing…everything looks great, but I put a little more grease in there.
To those of you that recommended the v-band, clamps thanks! It sure makes this much easier, and the fact that I put one in the y-pipe makes it pretty easy to take off.
Here’s a look at the O2 sensors…no codes, but the readings we’re looking a little mismatched between bank 1 & 2…
Also I see why
@cruisermatt isn’t too fond of these LS swap header collector o-rings, one use and they’re done….i already used my backup set
Hoping to dig in a little more this weekend & see how things go. Should have time to put the A/C system back together.
