OEM tank? Both of mine have drain plugs.I guess now comes the fun part. Getting the spare out, and lowering a tank with 12 gallons of gas in it and my drain pan is only 5. lol
yeah OEM - its just more stuff I really didnt want to deal with. I expected to be driving this to work by now lol Was supposed to be fully running/driving when I bought it and only sitting 2 years. Turned out to be 5 years sitting and not driven for decades. lolOEM tank? Both of mine have drain plugs.
Yeah I always reiterate to people I will take a high mile car over a low mile one ANY day. This is exactly why. Water pump was shot, I got a new one but they are a pain to get so I bought two. Few hoses are swollen, gonna do those too. The fuel issues. Tires are crusty and from 2016. Wiring stuff is easy, ive wired so many cars and used to do electrical on exotics all the time when I was a tech so all thats been a breeze. I currently need a headlight switch, and the turn signal combo switch on the stalk, but otherwise working great. THEN I get to the interior work. Which im probably going to just slap some blankets on and call it good.Welcome 2 Pigdom or any vintage vehicle!! Longer they sit more theya gots to fix
You gots to celebrate those victories!!!So today i took the rear hatch apart. To find there is a window in it, its just shattered. I shoved a screwdriver in the tract and pried out the old junk. I had the spare rear window in the back so i put some blue tape, and cardboard on it and put the tract back on and boom, rear window again. tunink. Motor has no power, so i hit it with the volt meter, and no power at the motor or the wooden spacer thingy. Oh well. But i noticed the pump sounded different. Lean down, and the filters are full!
So i let it idle while i farted around. And decided I needed to try to make it drive again, and it did. I drove up around the block, and then down to the gas station. Them tires got a MEAN wobble after sitting for so long lol but everything went great, suspension actually felt amazing. all three gears worked great as well. What a satisfying drive that was.
My '74 has a drain plug in the driver-side front corner of the tank...I guess now comes the fun part. Getting the spare out, and lowering a tank with 12 gallons of gas in it and my drain pan is only 5. lol
I knew a girl in HS named Marina...Buy a syphon. You can get a marina for like 10 bucks![]()
same spot for mine but I still only have one 5 gallon pan lol gotta drain some, plug it back, do something with that stank old gas (probably going to put it in the FJ but then im worried what its going to do to that fuel system), and drain some more, repeat 3 times. still have to get the spare dropped somehow. And do it all on the dirt with no jack.My '74 has a drain plug in the driver-side front corner of the tank...
is it the same crank as for the engine? because I have that. otherwise I have no idea. I have to get under there and look at it more, but we have 65mph winds today so the odds imma go sit in there and have a bunch of crust and crap blow in my face is low lolWD40 is probably your friend if the spare hasn’t been lowered in a while, especially if you don’t have the oem crank.
Me too, 55 gallons. I called my son over and we filled all his toys and mowers up, too.I had to do this when I filled my custom 40 gallon tank all the way
