TWT -- The Wrenching Thread (3 Viewers)
Non preventative maint
Bearing siezed. Composite pulley melted. Shredded the new SC belt. Took out the ac belt and twisted up the alt belts but somehow left all the other important pieces alone.
Lil help from Sam and I had the pulley numbers and found a belt number to get back In action. Except someone swapped belts in the sleeve at the parts store. This one is way too long an diff part number on belt vs sleeve :/
View attachment 2540453View attachment 2540455View attachment 2540454
Do you know how many miles you had on those failed pulleys? I might have to grab some spares for mine before I get stranded somewhere. I can add them to my spare belts in the back
Right at 150k.
The idler just started making noise the day before. Replaced the tensioner just because but it felt a little notchy.
The Workshop Series 1-38 (mostly)
Here's the list:
I found these today while looking for something else completely different (which is the way I always find the best stuff), and subsequently found pdf copies of most of them. The first 39 or so (above) date back to the mid 80's, but the material is pretty timeless. The individual topics are very well written; the target audience was/is model engineers in Britain. These are great references if you already know the subjects, and would make great learning aids, if you didn't! If you wanted new hardcopies, you really can't beat the price!
The issues from 39-49 I haven't found yet.
LMK if you're interested and I can either share my copies or post sites where they can be downloaded directly.
We have an '06 Sequoia with the 4.7; 160k miles... The catalytic converter rattles some at idle and when shifting between drive and reverse. I put a large hose clamp around it and tightened it down and it help some but still getting that annoying rattle. Is it always the outside heat shield or is it possible for them to rattle from internal parts that are loose? Its hard to hear exactly where its coming from but I'm pretty certain its the CC. Really hesitant to keep putting my head under the car while my wife shifts between gears; I think the life insurance would be too much temptation for her.
First off. CHOCK THE WHEELS ;)
But yes the cc honeycomb can crumble into pieces and rattle internally. Kick or Take a rubber hammer and tap on the converter when motor is off to see if you hear the jingle.
There also may be a heat shied on the firewall or manifold as well to check.
Regeared my ferd to 4.30 last night from 4.88. Ebay diff was cheaper than buying and setting up a new gearset.
Diff has to weigh 150#. It's a lump.
What was the main driver for this? Highway mpg?
This motivates me to crack open my stock rear axle that Fred Anderson grenaded with a lack of gear oil when they did my rear axle seals to see the damage. It's been sitting in my garage for ~6 months.
Reduce highway RPM from 2750 @ 70 to ~2300 @ 70, just to make it more comfortable on long drives. If I get 1-2mpg additional then I'd be tickled pink.
I agree. The center of the honeycomb inside of the cat can break off and rattle around. There's no way to see it unless the exhaust is separated. It happened on my old Maxima and sounded like I was dragging tin cans behind the car.
that a D110??
Dana S130 now. Was a Dana S110, yes.
Edit:
Funny sequence of events. 04 was the cutover year between dana s135 and the Dana s110, but both were still a funky 8 lug pattern from the earlier years. 05 went to a 10 lug Dana s110, and my 05 parts truck was used to convert my 04 to 10 lug. 10 lug hubs bolt right onto the 04 spindles.
The diff I bought just recently, and installed last night, was advertised as a Dana S110 4.30 lsd diff, and shipped to me with the differential and axle shafts. Upon receipt, I realized that the new axle shafts were 36 spline, not 34 spline like s110s. Dana s130 (not s135, s130) was introduced in f450/550 trucks in the late oughts, early '10s, as a slightly higher weight capacity axle, using the same brakes, bearings, axle housing, etc. Only difference is a tad larger ring gear, and 36 spline axles instead of 34. Capacity benefit doesn't really matter to me, as I'd never max it out in original config, let alone this new config.
Anyway, now I effectively have say a 2012 Dana s130 axle in my 04 truck, with less than 80k miles on it (new wheel bearings and brakes last year) that should go down the highway much nicer than before :D
Any tips on removing the square plug from the 2f to add the heater barb? A 14mm open wrench fits, but I have not been able to budge it at all. Have tried heat yet but will remove sending unit if I do. There isn’t much room to use leverage and I have never seem a square socket.
  • Back
