1996 Lexus LX450
It all started with Jim Brantley's Realcruiser.com, then meeting the Norcal guys and a few Socal Cruiserheads, and now the fantastic memories built along the way in the driver's seat of my 80!
Mods
-Slee Offroad OME Heavy lift, AC dryer protection, t-case skidplate, SS extended brakelines
-Hanna Quality Sliders, Rear bumper
-ARB front bumper
-Lightforce 170
-33" MTR's
-Engel fridge, Slee fridge slide
-Offroadair.net CO2 tank
As is the story with all the great Cruiserheads I have met, my friend Evan helped me deal with the only major problem-a leaky valve cover gasket. Thanks to C-Dan, I ordered the plug gaskets as well and glad I did. Evan has helped me and I have learned alot about wrenching from him and his generosity of time has been great.
Ken Hanna. I have known Ken for several years and he has been fantastic. I never felt my 80 was done until it was 100% Hanna-fied! I feel very lucky to have his work on my rig and you will find he is a no-nonsense, highly skilled craftsman with no ego and alot of pride in his work.
A driveway shot when I just got the ARB and MTR's on
I have to say that Slee Offroad has been stellar. They helped me alot when no one else even thought of OME for the 2003 4Runner. Ben at Slee's is the best and when it came time for the 80 lift, it's the only call I made. I think the 80 community is very lucky to have this caliber of vendor, it obviously works out for them too but it's certainly something to be proud of!
slow windows, cleaning window guides
forum.ih8mud.com
Power steering pump tips
forum.ih8mud.com
trans cooler soft line replacement tips
forum.ih8mud.com
Scangauge II
Got my Scangauge II! - IH8MUD.com Forum
_____________________________________________
Land Rover Cupholder add-on
Land Rover Disco cupholder
LED turn signal mirrors
side turn indicators
JO MAOMA 2Meter radio install
yaesa ft 7800 install - IH8MUD.com Forum
I ordered the RAM parts and they got here in 1 day, so I took 1/2 an hour to do this very cool setup- thanks Jo Maoma!
______________________________________________
PAINTLAB MIX™ MODULAR CARGO RACK SYSTEM
https://forum.ih8mud.com/merchandise-storefront/264008-interior-cargo-carriers-fzj80.html
_______________________________________________
PHH easy method
forum.ih8mud.com
TRD SC coolant hoses maintenance - by George Scolaro
forum.ih8mud.com
Changing Alternator brushes
forum.ih8mud.com
Never buy TYC radiators
forum.ih8mud.com
power door lock repair
forum.ih8mud.com
Sunroof alignment/possible help
forum.ih8mud.com
Pioneer 2DIN headunit - Bluetooth, USB, iPod, aux
Pioneer 2DIN headunit- BT,USB,iPod,Aux
Magnaflow XL stainless muffler
Magnaflow XL muffler
How to adjust your parking brake
Parking Brake weak?
Charcoal Canister Repair
Charcoal Canister Modification- need help
TEQ Blister Emblems
https://forum.ih8mud.com/4081905-post44.html
________________________________________________
Dual BlueSea FUSEBOX installation
Fusebox(s) installation - Bluesea
TRD Supercharger installation tips & extending wires
Supercharger install questions-vac hose routing
WAIC - Water to Air Intercooler
WAIC - Water/Air Intercooler for TRD SC
Mods
-ARB front bumper
-Lightforce 170
-33" MTR's
Got Slow Windows? Here's the Fix.
Slow 80 windows are a function of one or a combination of three factors. Weak window motors, replace with new. Grimed up regulators, clean and regrease. Stiff window channels, replace with new. Do all three and you’ll be golden. In my 24v hj61, I used 12v 80 series motors and they’re still...
1FZ power steering pump replacement...
why not just answer the guy's question rather than being vague and telling him to search? :confused:
Transmission hose replacement using non-OEM parts
what about instead of a unicoil just getting a 90 degree section of 3/4 heater hose or similar? I would think it'd be stiff enough to maintain the bend, but maybe not. could also 3D print a little curve that holds the hose. I was able to find the right part.. not on amazon but its available here
Scangauge II
PHH easy method
PHH
I read that Toyota sells the phh and hardline as one unit and if that's true, I would order that and use it. It all made sense to me after I read that. I think @pinhead wrote a good method. This was not a difficult job. It's fiddly, but doesn't take much time. It would be a huge pain if you...
PHH some other fun AND IMPORTANT S/C info
Replacing alternator brushes
Decided to replace the brushes on my 200,000 mile alternator as a PM today. First I removed the adjusting bolt, locking bolt, nut and pivot bolt as per the FSM. Then removed the three 12mm bolts that hold the power steering reservoir in place and moved that forward and to the side. I was...
Builds - ROTW- FirstToy
It may be one of these. From west marine.Did you see Mike? yup that is the one - I used the 6 space in my Tacoma - and the 12 space in the 80 - and used almost all the fuse space :) you can also find those here from the manufacturer http://www.bluesea.com/
Door lock motor failure-confirmed
Just pulled the failed door lock motor! PITA! And it’s the same as the rock auto lock I just bought! Did someone already replace these motors with ASINs and they already failed? Does anyone have a photo of the OEM part to compare? The motor you're holding in your pics is an OEM motor...
Sunroof Stuck
Parking Brake weak?
TEQ Blister Emblems
