Supercharger install questions - extending wires/vac hoses
The vac hose diagram is a bit unclear on this-
The 7/8th tubing that goes from the orange filter (under the intake manifold) ends up here (at the throttle body adapter). However, look at the size difference of the fitting and hose- the fitting is as large as the OD and the ID is quite a bit smaller-wtf? Am I mistaken on where this goes?
edit: this is indeed the correct routing. You must muscle that hose over the large fitting.
what is this for? threaded on the inside and outside
this is an extra fitting for the intake manifold if you want to add a sensor- (thanks hzavarce)
also some notes that might help with installation of the TRD Supercharger
Install tips:
Check this wiring- hidden by the air canister- but the heat wrap was burnt and desintegrating.
putting a photo to George Scolaro's excellent reference- move the heat shield out of the way to tighten up the SC plenum bolt
the wrench is the original location of the heat wrapped cable (goes to throttle body). Moved to other side of heater hose for smoother routing and no pressure on any lines.
Serpentine belt tool makes installing the SC belt a no-brainer. Get one.
Again, George Scolaro indicates this or shows how to make your own.
- still have to extend the wires to connect to throttle body. This will be the most time consuming aspect of the install. About 6" short at the "T" of the harness.
(I may try to go back further, I believe you can get away with cutting only a couple wires that way?)
- Pretty cool how simple it is to bolt-on some added power. So far the only tedious part is the wiring. Nothing else is hard at all.
- I found that the most frustrating things are lining up the fan clutch and shroud to put back in without messing up the radiator fins.
Still have a little bit to go but all the "heavy lifting" is done.
couple good links
(required reading) Kazuma Supercharger Install
https://forum.ih8mud.com/80-series-tech/236693-installed-supercharger-tips.html
thanks ahead of time for info on the top questions.
please read post #8 regarding extending the wires
Install tips:
couple good links
