- Thread starter
- #101
Great work on your rig, man!
Thanks, it's a work in progress but I'm loving it.
Have you checked your detent spring and ball bearing.
No. I have not but will research and see if I can find some info (part #s etc).
Love this pictureHad our first snow a couple of weeks back. My guess is, this is probably the first time the 60 was really put to use in 4x4. Hub locking seems to work fine but the selector knob kept sliding out of 4H. I've done a search but any advice where to start trouble shooting? Gonna need that 4x4 up here!
Love this picture
Just confirming - 4H and 4L work great with the new bearing and spring on the tractor in deep snow. Thanks to the great resource that is ih8mud.
Man I am so over snow blowing and shoveling at this point!
Maintenance day for the truck, I decided to do a test fit of a project I've been planning for a long time. Super stoked with the result!
Sun visors are next...
), in the meantime I am still having the issue with 4x4 shifter popping out of 4h (new detent spring and ball installed) and now my drivers side door lock is stuck. Nothing will get you going like climbing through the passenger door all the time I guess...Haven't had much time to tend to Cruiser projects (other than taking it fishing), in the meantime I am still having the issue with 4x4 shifter popping out of 4h (new detent spring and ball installed) and now my drivers side door lock is stuck. Nothing will get you going like climbing through the passenger door all the time I guess...
So, any advice on where to start with the drivers side door lock issue?
Many thanks.
Stuck how?
Key won’t rotate? It rotates but lock doesn’t pop up?
Rotation requires a cleaning and lubrication, the unlock function could be a plastic clip that holds the control rods in place. One could have come undone or broken with aging plastic.
If you pull the door Card ( unscrew 2 screws on arm rest, remove window regulator arm with small hooking tool or screwdriver) you can then carefully pull the plastic pins in the door cards around the edges of the door.
You’ll need to carefully pull the plastic weather barrier back and you should be able to see the lock linkage/lock core to see what is going on.
Key will insert but lock will not turn. It started intermittently but now it won't turn at all. You can unlock the door from the inside, just not via the external lock. Sounds like lock removal and cleaning is in order then?
I think the guy you're thinking of used the handle RAGINGMATT but he recently changed it to @ToyotaMattMan i can't remember the member's name here on mud right now but he makes keys and lock cylinders
