kcisland
Thanks for the compliments!!
Thanks for the fast reply! Yep, my rod ends are on back order so I will just wait. Totally makes sense on the filter!
So I hunted around my local car parts stores for replacement(s) for the FD vacuum hoses, individual or something that could be cut, but I struck out. Nothing even close to what was there (thickness, ID). Are yours new (along with those clamps - part # ?) and if so what did you use?
Do I just swap the pinion flange from one of the diffs into the ‘77? Is the spline count at the pinion flange end the same coarse spline?
If swapping the pinion flanges over do I just need a new pinion seal? Do I need to do anything special to not jack up the preload, etc.? I’ve never had the pleasure of setting up a diff...yet.
Yep - you don't need to worry about the seal and pre-load if you're just replacing flange. Just get it re-torqued and staked in the same placeCruiser Outfitters can hook you up with a new pinion flange. That would be the easiest if you don't have one that fits.
Cruiser Outfitters
Why aren't you using the axle that came with the truck?
Front axle close to being done, just need to pickup a set of hubs from @4LowandSlow one day this week and attach the tie rod. I pulled the one on the '67 axle, cleaned and painted it then added new rod ends only to find out the damn tie rod was like 8 inches short...wtf? Luckily I had a parts truck to rob a correct one from...cleaned and painted it. Should be dry enough tomorrow to assemble. Had no idea that some tie rods were short or maybe it's just some PO jerry rigged s***.
Also got the radiator and hoses installed...sans the bypass hose which I thought I had but evidently not. Ordered and should be here one day this week.
...and finished assembling the throttle linkage. Had to order an assortment of springs.
To top it all off, got my steering wheel back from Jimmy @Birdhead. So very nice!!
Short and not correct
Correct
Wow, it all looks so great!!! I wish mine was that clean. Cant wait to see this beauty all done and on the trail.I've been working almost round the clock on this trying to get it done for Relic Run...still have loads to do.
Got the rear axle rebuilt with new wheel studs and backing plates, rear discs from Poser, and bent up some brake lines. I had to swap another 3rd into the housing as the original one had tons of backlash. Upon close inspection when I removed the cover...the pinion had some wear on it.
Thanks to @red66toy I was able to get a set of rear tail light cone covers from another cruiser guy that did some repops. Nicely finishes off the backside of the taillights.
Almost finished refreshing my elephant horns. Had to make a couple gaskets, cleared the bodies after bead blasting and painted the plastic covers. Final touch is to add the repop aluminum label tags to them.
...and attempted to install the exhaust which is a NOS down pipe and new OEM muffler. For some reason the down pipe is too low...almost like the damn thing was bent wrong by Toyota. It needs to be 'up' about 2-3" for the stock skid plate to bolt up.
Am I doing something wrong here or is this just s***ty luck? Considering my options to either have an entire new down pipe bent of cut this one...??
Also finished up most of the wiring and brake lines...
