What about a 3fe head on a 2f block/h55 setup? I hear great things about that combo.
The 61040 us-spec 2F head may be discontinued, but the 61050/60/70 head are still available, just not through conventional channels.
This one is much harder than a Chevy v8 swap. BTDTWhat about a 3fe head on a 2f block/h55 setup? I hear great things about that combo.
Hmmm, good suggestion, I was thinking along the same lines..
Post up exactly what you need. I'd be happy to try and source them from this end..
In the meantime I'll check around for 75-80 o/s dome top pistons..
Gaz...
The cracking can be widespread & spidery. It is on the top of the head above the exhaust ports, often extending from a core plug hole out beyond the VC to the edge of the head. Welding or pinning is not a good solution. Actually, I am unaware of a solution, other than replacement.
