Home Forum Gallery CruiserFAQ Tech Links Store
IH8MUD Forum
Go Back   IH8MUD Forum > Toyota Tech Forums > 70-Series Tech
Follow IH8MUD on Twitter Visit IH8MUD on Facebook
70-Series Tech Tech assistance for the 70- thru 79-series Land Cruisers -- BJ74.com HZJ75.com
LinkBack (13) Thread Tools Display Modes
Old 11-24-10, 05:10 PM   11 links from elsewhere to this Post. Click to view. #1
crushers's Avatar
Troopie build
anyone interested in my next build?
we are all given sh*t in life,
but some of us learn to turn it into fertilizer and grow from it,
and some us try to fling it on others like monkeys.
3wheeling vids:
http://www.youtube.com/watch?v=U2Ra1QsyDts
http://s123.photobucket.com/albums/o...t=DSCN0379.mp4
Wayne in Ontario
www.luxuryimports.ca
http://www.ivoac.ca join
I play well with other's...
Other's, not you!!
Old 11-24-10, 05:14 PM   #2
Josie'sLandCruiser's Avatar
Hi All:
Damn straight we are interested Wayne!
Get busy posting pics!
Good luck with the project!
Alan
www.seattlecruiserheads.com
"Cruiserdrew" wrote:
"The very worst thing you can to to a cruiser is half thought out mods that are underfunded and never quite get finished. Then you end up with hacked junk that doesn't work, and some future owner will curse you and all of your children."
Josie'sLandCruiser is offline   Reply With Quote
Sponsor 11-24-10, 05:30 PM
Sponsored Link
advertisement
Old 11-24-10, 05:30 PM   #3
Deny's Avatar
Garage
Not really after you start off with a pic like that! Her build is much more interesting!
Diesels Rule and
Originally Posted by lshobie View Post
Spring overs are old school
81 BJ42 and a few other cruisers
Check out my endless fix up progress at /ca-bc-peace-canyon-toyota-swamp-donkeys/152995-bj42-winter-fix-up.html or my wagon beater that wasn't supose to be a project thread at http://forum.ih8mud.com/ca-bc-peace-...-anything.html
Deny is offline   Reply With Quote
Old 11-24-10, 06:04 PM   #4
1978HJ45's Avatar
Garage
Will she be featured throughout the build? ..........1978HJ45
1978HJ45 is offline   Reply With Quote
Old 11-24-10, 07:14 PM   #5
that's pretty sweet. and that would be just irresistible if that first model comes with it
Scud1373 is offline   Reply With Quote
Old 11-24-10, 10:44 PM   #6
70's Nut
ForealBoreal's Avatar
Garage
Wayne I only thought you did engine transplants not boob enchancements
1996 HZJ77
ForealBoreal is online now   Reply With Quote
Old 11-25-10, 01:21 AM   #7
Clint79's Avatar
No sub tank on a Aussie troopy that's rare
FZJ-79 SERIES 4500EFI
TURBO.INTERCOOLER.LPG-INJ.LOCKED.ZX SPEC DOORS.105 SERIES GX RIMS.3" ZORST.PATROL SCOOP.
Clint79 is offline   Reply With Quote
Old 11-25-10, 01:48 AM   #8
crushers's Avatar
the old girl moved into the shop yesterday to get a 1.5" body lift.
since this is a very extensive build i needed the lift on to set up for the rear PTO winch, the proper height for the side bars, location of the top of the bumper, the front side bars and the location of the rear bumper and side step.
first things first.
here is a list of what is being done to the truck over the next few months:
P/C = sand blasted and powder coated light matte grey
Metric bolts through out, S/S preferred where acceptable in tolerance specified, plated where strength is needed.
Steel below window height, alloy above window height.
Painting and final prep of body to be arranged by customer.
PTO winch rear with possible shaft drive to the front. inspected and corrected, painted.
Tabs for lights
Protection for lights P/C
Skid bars from under bumper to below rad, P/C
Shackle protectors, P/C
Custom shackles, P/C
Bumper like the original Roo bar but in steel and modified accordingly with tow triangles, P/C
Front HD 70 series front diff dismantled, rebuilt using top quality parts, P/C, factory electric locker, HD birfields, manual locking hubs, vent line to frame.
Dobinson spring pack with rubber bushings
RS9000 shocks
Dropped sway bar mounts
Frame, modified as required, P/C gray, same gray as all the other P/C stuff
Engine/tranny/ t/case removed, replacement inspected, corrected reinstalled
Turbo, top mount intercooler, air compressor, wabasto, sensors, manual glow system, upgraded alternator, dual batteries with isolator,
Larger rad (check for alloy replacement),
Factory viscous fan.
Full Clutch replace with slave and master also replaced with new
Rear full floater diff removed, dismantled, P/C, reassembled with factory electric locker, vent line to the frame level.
Driveshaft inspected and corrected, P/C
Secondary fuel tank installed, P/C, S/S fuel line to the front with feeder pump and dual filters. Must have drain in S/S fuel tanks (both) at lowest point of tanks; drains must be lockable when shut.
Skid tube protection, P/C
Side bar protection with expanded steel “running board” and removable fender protection front, P/C
Rear bumper with dual removable swing out tire carriers, hidden winch, hitch, wiring, tow triangles, signal light inserts protected by expanded steel, P/C
Skid bars to rear of axle and out the side of the body to the outer edge of the tires to make a step with expanded steel.
1.5” body lift with grade 8 bolting applied.
Remove side windows and replace with alloy panels with storage boxes and access from outside. Send side windows and associated trim with finished vehicle.
Inner rear doors with drop down panels with storage inside, P/C
Inner side panels with inner storage, interior and exterior access, body colour.
Front door panels leave alone.
Rear diff fluid level sensor/t/case level sensor/tranny level sensor/pyrometer/water temp/oil pressure at turbo gauges. Factory gauges still functional.
No stereo or speakers-another item to be sorted out by customer
Wabasto heater.
Interior rear heater hooked into plumbing with remote switch.
Cargo barrier with access slider to rear and removable from truck, P/C
Hidden floor boxes were possible.
Hood strong enough to walk and stand on left in whatever finish it came with; intercooler scoop and receiver for windshield protector screen.
Alloy windshield protector screen, P/C, removable with top mount clips.
Alloy roof rack with tabs for 4 front off road lights and protection, receiver for windscreen, slide out sand bridging, rear back up light tabs, disconnect electrical wiring for removal of roof rack, mounting for roof top tent, fold down rear storage flap for sand bridges, mount for high-lift and shovel on side but tucked in tight, single level, tabs on the front for removable wire rope, P/C
Small roof vents, four if possible, that are sealable when closed, low profile.
Rubber flex mud flaps to be installed at all 4 wheel openings.
Water tank under body 50L size, with S/S fittings. Must be removable.
starting on the body lift:
3wheeling vids:
Wayne in Ontario
Other's, not you!!
Old 11-25-10, 01:53 AM   #9
gotoy's Avatar
Why would you be having a pto at the rear as opposed to an electric?
Also, is this for a customer?
Shoould be an interesting build and I hope there's plenty of pictures.
gotoy is offline   Reply With Quote
Old 11-25-10, 02:04 AM   #10
crushers's Avatar
low profile winches are shit in my world. i looked at doing a 8274 at the back but not reasonable. we looked at making the winch a slide out but not feasable.
the customer wanted the shafts for driving other accessories and made the decision to go with PTO. sorry if i came across suggesting this is for me, i can't afford these builds.
3wheeling vids:
Wayne in Ontario
Other's, not you!!
Old 11-25-10, 04:16 AM   #11
What about making the water tank sit on 4 rails. The tank slides between the gaps and pins in place using bolts. Just make sure the Owner knows to empty the tank before mounting and dismounting. The hardware has to be at one of the ends with QD hardware. There should also be a supporting strap just to be safe secured to the frame.
__ __
__ __
fzj75macka is offline   Reply With Quote
Old 11-25-10, 05:30 AM   #12
1978HJ45's Avatar
Garage
No grease or goo on the floor of your garage.....just what kind of mechanic are you? ..............1978HJ45
Old 11-25-10, 06:06 AM   #13
crushers's Avatar
i run heavy gauge polly most of the time and it catches most of the crap, you will see it down again once we start on the tear down or fabrication work.
i have not decided what to put on the floor yet so just trying to protect it till the decision is made. paint is nice but slippery, tile is nice but is it practical? epoxy is like POR, once it is down you are fawked if something goes sideways. mats might be the answer or just polly for wrenching and plywood for fabrication.
hummm,,,
3wheeling vids:
Wayne in Ontario
Other's, not you!!
Old 11-25-10, 06:27 AM   #14
I am looking at the low VOC polyurea coatings as that is what they use in the papermill up here and it is seriously tough stuff.
Old 11-25-10, 06:40 AM   #15
D'Animal's Avatar
Garage
I saw one of these in person at SnT 2010. Cool Rigs! Good luck with the build and her.
http://www.rockcrawler.com/forum/
2012 President - Central Valley Crawlers
D'Animal is offline   Reply With Quote
Old 11-25-10, 09:25 AM   #16
lshobie's Avatar
Will be interesting to see how you run the PTO shafts to the rear winch since the shaft hooks up to the left side of the winch (from the drivers seat), right in the middle of the rear gas tank. And, wouldn't you only be able to wind in with reverse? Or are you making some type of gearbox? You'll have quite the time with that
The new 79 series rads are aluminum, I never have cooling issues, but my truck isn't packed with gear.
Louis
"At the end of the money why is there so much month left?"
Check out my off road landcruiser videos at: www.youtube.com/lshobie
Join the True North Toyota Land Cruiser Club in Ottawa http://landcruisers.ca/
lshobie is offline   Reply With Quote
Old 11-25-10, 01:07 PM   #17
crushers's Avatar
Louis,
the shaft will run to the LHS of the vehicle same as the front.
the PTO is a worm gear and doesn't care if it is turning right or left.
the PTO will be flipped and the cable will be coming in from the top of the drum OVER the rear frame cross member. there will be 5 speeds coming in. the down side will be if he wants to be able to winch in AND turn the tires in reverse then he will need to wind out the cable and feed it back in UNDER the rear frame cross member.
clear?
new as in all 79 series or just the last couple years?
3wheeling vids:
Wayne in Ontario
Other's, not you!!
Old 11-25-10, 01:14 PM   #18
Hulsty's Avatar
How do the fluid level sensors in the diff and transfer work?
Doesnt look like it has a rear tank, spare is underneath not on the door.
The Silver Bullet - BJ74
http://forum.ih8mud.com/70-series-te...r-buildup.html
Where the actions at Ontrack 4wd Club
http://www.ontrack4wdclub.com/
http://www.cams.com.au/
Hulsty is offline   Reply With Quote
Old 11-25-10, 01:46 PM   #19
crushers's Avatar
Rad:
thanks Louis, ordered.
Gauges,
as far as i know the low level sensor carries a current as long as the fluid is up, once the fluid drops it breaks the contact and the light comes on.
Rear tank,
correct, there isn't one plus the shaft for the PTO will be running in the void above the frame.
3wheeling vids:
Wayne in Ontario
Other's, not you!!
Old 11-25-10, 02:31 PM
Sponsored Link
advertisement
Old 11-25-10, 02:31 PM   #20
lshobie's Avatar
Sorry, thought you were adding a secondary tank - thought it went under the back of the truck - like on a 73/74/70 etc.
So how do you operate the lever for the freespool? Will the winch be well out the back of the truck?
Louis
Trackbacks are Off
Pingbacks are Off
LinkBack to this Thread: http://forum.ih8mud.com/70-series-tech/436341-troopie-build.html
Posted By For Type Date
70 Series - Troopie 1HDFTE • Land Cruiser Club and Forum This thread Refback 12-03-11 05:34 AM
70 Series - LJ70 Build Thread! • Land Cruiser Club and Forum This thread Refback 11-23-11 01:54 AM
פרוק והרכבת 75: עוד פסיכי עם הרבה זמן ומשאבים This thread Refback 11-19-11 12:19 AM
Troopie build This thread Refback 10-31-11 03:04 AM
Southern Ontario Toyota Trucks • View topic - Land cruiser troopy on Kijiji This thread Refback 10-30-11 06:11 AM
Revisar el tema - A Quien Le Gustan Las Reformas?? This thread Refback 09-20-11 01:52 AM
TEMAS GENERALES DEL GRUPO :: A Quien Le Gustan Las Reformas?? This thread Refback 09-20-11 01:48 AM
What car is your favorite and why? - Page 7 - JDMVIP Forums JDM Japanese Cars Import Used Auctions This thread Refback 09-13-11 06:27 AM
www.pasion4x4rosario.com.ar • Ver Tema - algunos mostros que todavia nunca manejamos... This thread Refback 08-31-11 07:56 AM
Crushers This thread Refback 07-17-11 04:35 AM
Crushers - CT4WD Forum This thread Refback 05-23-11 07:36 AM
Crushers - CT4WD Forum This thread Refback 05-23-11 04:07 AM
70-Series Tech on IH8MUD.com Forum - The Truth is in the Rocks | BoardReader This thread Refback 12-08-10 07:19 PM
vBulletin® ©2000 - 2012, Jelsoft Enterprises Ltd.
©2000-2012 by IH8MUD.com - ALL RIGHTS RESERVED
