Gamiviti 200 series products & solutions (16 Viewers)
All should be very doable.. in fast I'm most of the way there already with this first version. I will post up an update once I get the flat one installed, review rev B of the tall one, and then start working on the sub 2016 version. Really appreciate all the input thus far. :cheers:
Do you know of anyone who is running just the towers/crossbars for a RTT mount? I'm thinking that may be as close to a direct mount RTT kit as I can get. Certainly utilizing all four towers on each side/crossbars would provide a stable and strong enough platform?
Yes, several people. In fact we probably sell as many tower sets as we do rack packages... and it's unlikely all those people are building racks, most are just running cross bars. Also yes if you ran 4 cross bars it'd be a pretty solid setup. Personally I'd just do a rack, as once you add up all the parts to cobble a cross bar system together you're likely halfway there anyway... then you get the added benefits that come with having a rack. Of course I also make/sell racks so a little bias there. ;)
Thank you for the info! Coming clean I actually have a Front Runner mounted up right now which is very tall with the tent mounted. I've been exploring ways to get the lowest profile tent mount in hopes of being able to fit in the garage with it mounted. It uses it's own proprietary crossbars which would easily work with your towers. Need to get a few things put on suspension-wise still so I can know final height to see how much room I've got to work with, but I'd love to be able to throw a hoist in the garage and have the ability to swap between the tent and a minimalist rack from you.
But the thing I'm most excited about today is a new one I swear you haven't seen before... hope you're sitting down. ok j/k. It's a replacement speaker screen for your upper dashboard insert on the 2016+ Land Cruisers... no cutting, welding, you just pop off the panel, remove the screen, then add this new sheet metal bezel in its place. Some pics:
I made 3 different versions of the front plastic part, the one shown is with 5 round holes for 12v outlets, etc. #2 has 2 round and 4 rectangular openings, and #3 has 2 round and a big rectangular opening in the middle that will fit a Switchpro. You can also run 5 holes without the plastic in front, as the steel also has that 5-hole pattern (which you'd trim to run a different one).
On my rig, I put that Garmin there just for looks, that'll most likely move to the right side, and on the left will be my Ham Radio faceplate. I'm just waiting on a few more Ram parts for that one. The USB/volt meter on the left is from the primary battery, the one on the right is the 2nd battery, the 12v sockets are split also. And that center switch kills them all.
The top of the part also has a ton of holes for bolting up additional Ram mounts, also a couple bigger holes for grommets & cables, holes for the speaker, and another hole for the headlight light sensor. I'm pretty good and putting holes through sheet metal in CAD. :rolleyes: But hey pics are always fun, so here's what that looks like on the screen:
So I'm curious if there's much interest in these? Or if anyone wants to try one out? Or if there are any other objects you wish you could stick onto the top of your dash, which would be appropriate here. Thank you all for your continued support, and I appreciate all the comments. -tim
I am very interested in the speaker grill replacement; and at a $100 price point, I would buy one immediately. No other vendor on here, or otherwise, is offering this clean (67-Designs-style) solution to the market.
I think as long as it has provisions for a RAM-style rail and a couple of USB ports, it would be golden. IMO, less is more with these type of dash mods that are in your face when behind the wheel. I like the flat design, as I think it would offer a less cluttered appearance while still being functional.
@nakman I’m in whenever you have production units available or if you need any prelim user feedback.
Cheers,
-Steve
I’m running his towers and only three crossbars under the largest CVT and it’s plenty secure even on rough off-road tracks. His towers are stout 👌🏼
@nakman this is awesome! You should post new products like this on instagram. I didn't even know this was going on! I guess I should check Mud more often😬 Cant for the 13-15 version👍
right on thanks Lee, yes will for sure let you know when I have the 08-15 version ready... working on that this week actually. And yes will post to the instagram also, and do a video also for sure. I'm liking it better with my radio faceplate mounted to the side, seems to fit well:
But I already want to try the lower version without all the gauges... :rolleyes:
Update: I received the first prototype of the lower model, already made some changes to improve it but so far I am digging it. Here are some installed pics:
I am going to make it a little bit taller, like 1/4" taller so that there's a little more clearance below for nuts & wires, as this one is a little tight. But it totally works, feels solid, I'm liking it. I also spent a little time working on a web page, including some installation instructions, links to the various mounts, etc. Dashboard Accessory Mounts — Gamiviti - https://www.gamiviti.com/dashboard-accessory-mounts
I've got these low ones in production now, for both the 2008-2015 crew as well as 2016-2022. I hope to have stock in a matter of weeks here, it shouldn't be too much longer. Excited to see this happening here.
Very nice! 🍻
Can't wait for the LX flat version!
Looks great, thanks for doing this!
Awesome...looking forward to the final solution on this one! You can almost definitively count me in for one.
A fine set of quality products and an awesome dude to deal with :) I have purchased racks and accessories from Gamiviti for mine and my daughters trucks and never been disappointed
