Dobinsons 3 inch Progressive / Flexi coil review (2 Viewers)
That last pic tells the main story too Adam, very well for the tapered dual rate.
Theres a small amount of progressive rate in that last wind before the secondary rate, where it gives that little bit of softer rate before it goes to the full hard rate, but not that much the car feels "tippy" or unstable, with the shock package especially.
The softer rate open as you say for traction, but also for stability, when the vehicle is stretched out and near its limits, you have a softer rate exposed, which wont upset the car or make it move around corner to corner or side to side as much, because of the softer rate, but it will keep the tyre pressed into the traction surface. When your on the washboard roads, bad back roads etc though, you have a small amount of give as it increases rate a little for better on road ride. We also tend to go a slightly softer rate on the heavy one, but a slightly taller free height, so we can have a better unloaded ride quality as well, but the spring will sit at the required height at the rated load.
They are important factors in heavy touring and overland trucks to ensure they keep the rubber side down.
This pic illustrates that well I think, for anyone who has seen Cruisers drive across this, car rocking, left front wheel in the air, bumper dragging, Woody has stage 4 slinky long travel intermediate package in Gretchen for afew years now, and in the pic you can see how theres softer rate to keep tyres on rocks, and enough travel to keep them there, and as the car comes back onto the coils and they compress, the coil rate increases to prevent momentum getting a run over the suspension.
Yet you can go bombing in the dunes, being chased by a U4 truck, loaded, windows up, AC on, drink in the cup holder, smiling from ear to ear, when you have your 80 "off the leash " :)
That video would convince most to buy Slinkys immediately. With my Frankies Off Road springs and blown out Bilstein shocks, I couldn't maintain a 1/3 of that speed.
My intent when creating this thread was to review the Dobinsion 3'' coils. @Box Rocket and @AutoCraft Aus I have heard nothing but good things about those coils you are promoting. However, I do take exception when you shamelessly plug your product in my thread. I am certain there is another thread somewhere that your posts would be more appropriate.
@half k cruiser
Do you have any impressions on flex yet? (and pictures!) It seems like a lot of LC suspensions are sprung rather stiff and don't take full advantage of the LC's available suspension travel. It would be nice if there were multiple options for buying springs at the right rate(s) and free height.
@half k cruiser
I am hitting the Kokopelli trail and Moab at the end of the month. I should have some much better pictures and impressions of the springs by then. I will make sure to keep this thread updated for everyone interested.
No worries. The intent wasn't to "plug". I've removed several posts that weren't relevant. I did leave a couple posts regarding technical info of different coil types. Thought that was still useful information for those investigating.
Is your Cruiser your daily driver? I would be interested in your thoughts on road manners and small bump characteristics.
Agreed, there is some good information there on different spring types. Thank you for your contribution.
Yes, I've had the same suspension setup on it for the last two years so I have a pretty good idea of how it felt before the spring swap. I am waiting to see if the coils settle a bit then I will install the new drag link and stabilizer. I am also going to try and get my front sway bar back on the truck and see what kind of difference that makes.
What length shocks are you running or going to run
When answering tech questions with tech answers, you use what you know, and have access to to be able to paint the picture that can then be understood.
At no time was any comparisons made, or a link to buy etc, was just technical details explained to those asking with the tools at hand.
If that helps people understand what the actual details are, and to be able to better understand your updates going forward, after all, shocks are a big part of the package, compared to just springs as has been discussed, [no use using longer coils if your shocks arent long enough to use the dua rate or progressive section] then everyone wins I would of thought.
Yea but I don't think those fox are long enough for your full potential, when I talked to down south the guy there told me would be a tad shorter then ome Ls, so was just wondering what length you were gonna try
Let me try and find the info again tomorrow. These are the 3-5'' versions and I remember them being a bit longer than an L shock. When I disconnected them to install the springs I had to drop the axle almost all the way down to get them to come out.
My Fox 2.0's arrived today. Hopefully I'll get them on this weekend.
So a local mud member was asking me today about the cost of these springs and I thought it would be a good idea to clarify on here. The springs are $250 a pair, not a piece. So for $500 you can have all four corners dual rate.
I'm new to the lift part so excuse the stupid question, but can I basically just install these springs and get a 3in lift? Do I have to do anything else besides check the drag link (I saw you mentioned it pulled).
A couple of shots for those that want to see the stance of it. This is ride height with my normal load out. For trips there would be an additional 400-600lbs of gear towards the back. I will have pictures of that soon.
To do it correctly, you will also need new shocks, longer brake lines, adjustable/longer panhards, some kind of caster correction.
You could but it will drive like crap. At minimum you need to look at your shocks (they need to be long enough to support the lift), I would do longer brake lines so you don't stretch one out (lots of options out there for this) also sway bar drop blocks. Castor correction would also be high on my list. You could do panhards and control arms as well, but they won't be completely necessary, just nice to have. I imagine if you called the vendor he could quote you for an entire kit that has everything you need.
Like the wheels.
Thank you. I blatantly stole that idea from another mud member !
