- Thread starter
- #341
Basically the LC uses metric sized hardline which is not available in the USA. -6AN hose is almost the correct size but a little too small. So while it is possible to install it with some wd-40 when its off the vehicle, after several months of use you will have to cut the hose off the reservoir hardline to be able to remove it. Then this will require a completely new hose or a splice with a double male barb.I'm curious why you went to the trouble of brazing the fitting to the low pressure line on the reservoir just to go and clamp the hose to a barb adapter anyways? Why not just clamp the hose directly to the unmodified reservoir?
Its rather interesting that the AT cooler stuff works great with standard 3/8'' hose, I suspect that its designed this way intentionally to keep people from doing stupid things, just like all the different gas fittings we have with the intention of keep inert and combustible gasses separate, you know how some things are reverse thread and others are not. Just a hunch? No lo se guey.
But as it stands now, everything is done correctly and should be easy to service with simple tools in the field should it be necessary.
