Yes yes I know, but doing any swap (trans, engine, etc) would be much easier! 8HP90, LS3, hmmmmNo body’s checking transmission at smog checks !!
No, that's a huge benefit of this conversion....same drive shafts, same mounts, same skids, etc. All possible with the custom bell housing that they are putting to market.If this has already been stated I missed it. Are driveshaft changes needed?
I linked the white paper from Toyota specifically about the change from the 343 to the 750 and it has been years but I think they said it was 18%. It is in one of these threads about swapping in the 750 that I started.Minimum 15-20%
Oh the link is long dead, I never would have guessed it was 12 years ago. lol But Toyota says 12%Brain is still turning, but in my searches I found this pretty cool document.
http://m.doc88.com/p-583712611999.html
It describes the A750F vs the A343F.
It says the size and length were kept the same, and that the power used at certain points is 12% less. In a drivetrain that losses 30+% of the engine's power, swapping an A750 would give you a nice feeling of increased power.
Usually, I get around 10-11mpg. Grand Junction to Idaho Springs on the way back from CM was 13 mpg on the dot. At or above the speed limit the whole way up the Eisenhower and vail pass. 12.7 on the next tank, and we'll see this evening what I got this tank. Definitely an improvement.I linked the white paper from Toyota specifically about the change from the 343 to the 750 and it has been years but I think they said it was 18%. It is in one of these threads about swapping in the 750 that I started.
well that's pretty compelling.Usually, I get around 10-11mpg. Grand Junction to Idaho Springs on the way back from CM was 13 mpg on the dot. At or above the speed limit the whole way up the Eisenhower and vail pass. 12.7 on the next tank, and we'll see this evening what I got this tank. Definitely an improvement.
For reference everyone... 35's, 4:10 diff gears, no high range tcase gears, truck when unloaded is ~6500 lbs. Before I'd be lucky to go 200 miles before the Empty light came on when dailying my 80 and it came on this morning right at 241 miles. Definitely an improvement
Interesting. So if those are in fact the only two differences, in theory a male-male stub shaft could be made that could accommodate the internal splines of both the Tcase and tranny. Then the extension housings could either be swapped or adapted. I know in the latter case it would mess with driveline lengths...unless of course, there were another version of the bellhousing that subtracted the thickness of the Tcase adaptor plate (not sure if that's possible and would be a huge ask if so).Here is a comparison of the 4-Runner A750F vs the LC A750F extension housing
4 Runner (also GX, Tacoma, etc) A750F extension end, 8 bolt pattern, splined, internal output (t-case inserts into transmission)
Land Cruiser A750F extension end, 6 bolt, exposed output shaft, has mount for range select lever (Which is still installed in this photo).
Everything forward of the output shaft and extension housing appears to be identical, so it does look to be possible to convert an A750F from one style to the other, the parts are very expensive. The LC extension housing alone is over $1000, and the output shaft (which is attached/part of the first planetary assembly) is over $1500, so at least $2500 in parts to convert a 4Runner trans into an LC trans and you'd have to fully disassemble it to get at the output shaft.
Found this post that highlights a couple other differences, and seems to be at odds with the earlier statement that the non-LC/LX output shafts are internally splined:Interesting. So if those are in fact the only two differences, in theory a male-male stub shaft could be made that could accommodate the internal splines of both the Tcase and tranny. Then the extension housings could either be swapped or adapted. I know in the latter case it would mess with driveline lengths...unless of course, there were another version of the bellhousing that subtracted the thickness of the Tcase adaptor plate (not sure if that's possible and would be a huge ask if so).
Well, I got the output shaft swapped!
View attachment 2016542View attachment 2016544
(left, the final product, the 4Runner-turned-LX A750F. right is the differences between the 4Runner and LX shaft, respectively)
There were two very notable differences that were thankfully solvable. First being the park/neutral switch being different (pin out was different on the 4Runner). I just switched switch from my LX's old A750F and it was good!
The second was that the shift lever bracket was different. Once again, the LX's lever swapped over without problem.
The 4Runner A750F has a few different brackets to swap from the LX's A750F, and the 4Runner had two extra brackets not on the LX's, so those were just removed.
Disassembly of both transmissions (at the same time), wasn't too bad. Good snap ring pliers are definitely needed.
Here is a pic of the 4Runner and LX's AT filters, respectively:
The LX had a TOAST clutch in the C2 pack.
The fluid coming out of the 130k 4Runner A750F was dark brown, near black, but it IS Toyota's 'Lifetime ATF', so that is to be expected. After disassembly, it was cleaned/purged with new AISIN WS ATF:
And, lastly, a look down the throat of a healthy A750F.
I'd rate this probably ajob, maybe five (guess we will know soon enough).
It's very possible there are variations within the 4Runner, GX, Tacoma or over the years. The photo of the 4 Runner version from I believe a 2007 four runner appeared to be internally splined. I think the point is that the LC trans has a specific extension case and output shaft size/splines that directly accept the 80 series transfer case, whereas all other variants do not. If someone wants to swap out extension cases and shafts, I'm sure it's possible but the cost effectiveness of doing so is in question. Maybe in some very specific cases it might make sense to do so, but for most I think acquiring the proper version up front will be the best route.Found this post that highlights a couple other differences, and seems to be at odds with the earlier statement that the non-LC/LX output shafts are internally splined:
AgreeAs for the complete kit, I don't think I want to have to use the existing shift cluster, I'd rather put something more modern in that matches the transmission and I'm happy to source those components and do that work myself. Alternatively some different programming might work, maybe having the existing shift cluster and OD buttons do exactly what they are labelled and the 'PWR' button simply switch to paddle shift only mode. I don't like the way it was described as working with the existing buttons.
When I made my earlier post I had naively assumed that all the "other" A750F's were different in the same way, and that they could all be made to work with the same bit of additional kitting. That would have been nice since there seems to be great deals on some non LC/LX 750's, but the more I look into it there seems to be variants across several years and models.It's very possible there are variations within the 4Runner, GX, Tacoma or over the years. The photo of the 4 Runner version from I believe a 2007 four runner appeared to be internally splined. I think the point is that the LC trans has a specific extension case and output shaft size/splines that directly accept the 80 series transfer case, whereas all other variants do not.
Fill up today was 12.6 mpg. Definitely the most efficient the truck has run in forever.well that's pretty compelling.
edit: but I'm still nervous about anything Wholesale Automatics makes. Makes me pray that nobody has to deal with them directly and can always go through you, Johnny. The transmission I had from them made it a whopping 1000 miles and I threw additional thousands at it before giving up on the rig entirely because I was so frustrated. All they wanted to do was sell me more and more parts and gauges to try and fix it.
Please see the above.I'm also in the camp of hesitation to work with Wholesale Automatics as well based on my own past experiences.
It takes some slight getting used to but after a week I had it down. It is simple once you wrap your head around it and keeps the interior side of it clean. We tried a few different shifters and kept coming back to keeping the factory unit. Paddles you’ll simply have to touch them to kick on manual shifting and long upshift hold to return to automatic shifting.Agree
The A750 only has 6 positions so it would not work with the fj80 shifter.ea with the power button. I myself would like the interior to look original but still retain a more "traditional" way of selecting at least the lower gears. Maybe switch to the FJ80 shifter that has 7 positions instead of the FZJ80's 6 positions.
Are we shifting the conversation back to my Lexus shifter question I had a few months ago?As for the complete kit, I don't think I want to have to use the existing shift cluster, I'd rather put something more modern in that matches the transmission and I'm happy to source those components and do that work myself. Alternatively some different programming might work, maybe having the existing shift cluster and OD buttons do exactly what they are labelled and the 'PWR' button simply switch to paddle shift only mode. I don't like the way it was described as working with the existing buttons.
I will take you up on that, if the offer still stands (or is even relevant) whenever I can make a drive that long.@COS80 if you want to come and go for a drive I have the truck ready so you can try it and a “version” (momentary rocker for testing lol) of the paddles is plugged into my 80. You could report back to everyone your findings!
Always, and I am down that way from time to time for other work (the other business) so maybe next time we need to go down that way I will drive the 80 and give you a heads upI will take you up on that, if the offer still stands (or is even relevant) whenever I can make a drive that long.
