- Joined
- Jul 22, 2012
- Threads
- 584
- Messages
- 16,426
- Location
- Winter Park, Florida
- Website
- www.cruisermatts.com
- Thread starter
- #1,841
Currently working on re doing my motor mounts before i pull the broken transmission out (as it's locating everything and I can actually sort of move the truck around under it's own power, albeit forwards in 2nd gear only). Unfortunately the 80 series rear link bushings i had been very happy with for the first two years of the engine swap started suddenly degrading hard a few weeks before I left for my trip and throughout the trip completely degraded into nothing, this resulted in the passenger side frame mount ripping completely off the frame on the Rubicon. Not sure if it's the heat, the flex gaps in the rubber that those bushings have, or if it's just because they had 250k miles as control arm bushings before they were engine mounts, but I think this setup was just a touch too rigid which was a contributing factor in the bellhousing cracking, and I should have plated the frame on the passenger side to begin with so I decided to just re-do the setup. The joys of experimentation. And I'll never resort to those awful AA universal motor mounts
Time for a new setup.
I'm using a Envoy/Trailblazer bracket/mount on the passenger side (this is actually a driver's side bracket and mount but I only have this side for whatever reason so it get's used, no functional difference other then some clearance needed on the AC compressor bracket). I've accumulated a nice pile of various mounts and brackets from LS engines I've pulled from different applications, this one seemed to offer the most amount of cushion/fluff and seemed to be the easiest to build for as it sits pretty flat compared to the more common Tahoe/Silverado mounts that need a weird, inverted 45-degree mounting. As mentioned I only needed to make a new frame bracket. I'm thinking this large fluid-filled mount will take out that harsh impact loading the passenger side (compression) sees when flooring it in low gear. Regardless, this time I way overbuilt the frame mount for this side, all 1/4", including the frame spreader plate.
For the driver's side I'm sticking with a bushing/bolt setup, however loosing the 80 series suspensions bushing for a much larger (and fully rubber filled) leaf spring bushing for a Jeep Cherokee, it's large and has a easy OD, 2.5", and I had 2.5" pipe on hand, and it was about $8 and could get it same-day. Plus common easy replacement is a nice bonus.
Just need to finish welding the other side bracket to the frame and I will work on some frame tabs for this this side.
