Builds Cruisermatt's FJ62 Build-up (7 Viewers)
Just picked it up...
Just so everyone is aware, this will have no effect on the build of my current truck - everything I have planned for it is still in motion.
35's look so right on a 62.
New 1997 4Runner wipers with 19" wipers. They aren't as fast anymore but they wipe a lot better so whatev. Might throw a relay in there or something.
Also got my new wiper jar, my old one was yellow and cracked and my new lid wouldn't stay on. This one includes the lid, grommet and both pre- and post- filters, which are NLA. Also bought a new pump and then found out my old one worked :doh:
The Tacoma rims that I run have these nubs that center them, when I had the semi-floating rear axle I tried to grind down a couple of them on one rim so I could try to mount the rear "Toyota" hub caps. I gave up halfway so that rim can't be on a balancing machine :doh:
My 80 chassis came with two Tacoma rims so one to replace my screwed one and my steelie spare.
Are those IFS-offset rims to go on a solid axle truck?
These are Tacoma Pre-Runner wheels from the 2006-2015 trucks. They have ~5.5" backspacing so they don't stick out too far with the rear axle swap. When I narrow the rear end I'll probably switch to something a little more retro looking like 15" FJ40 wheels.
Got the rims swapped, nice to have five matching tires AND rims. Here's a picture of how it looks in my cargo area on an organized day
Matt, where did you get the windshield washer reservoir? I need one bad.
toyotapartsdeal.com or Beno
JIS Nuts from McMaster. Going to try to return this whole truck to bolts with either JIS or SHCS heads. Won't be that bad, my dad replaced a few with stainless way back in the day so it's not that much.
Rescued a Jeep today
And then broke a birf. Unrelated incident...
Nice! 35s + locker = broken stock birfs. Is that the short side?
