Which plates? Not all plates are created equal.
They are my design as they do not hang below the control arms.
Yes I would agree that not all plates are equal in caster correction or ease of installation.
Wow, that's awesome. Are you a engineer?The change in caster angle is not linear with the increase in lift height. It is the inverse sine function of the lift divided by the control arm swing length at the point where the lift is measured. The first inch is 1.7 degrees, the next, 1.75, the next 1.83 and so on. It is the "invsin" key on your scientific calculator. Divide the lift height by the control arm length and then hit the invsin key. On some calculators it is called the arc sine function or arcsin.
Is your front driveshaft stock or DC?For reference - My center of hub to underside of the flare measures 23" with a small amount of front to rear rake and my caster is at 4° using plates.
Invsin is "Sin-1" correct?
Good to know, thanks for posting this.
Redline Cruisers is selling one that moves up to 8mm. It's blue, I can't remember the manufacturer name at this moment.has anyone run an offset bushing on the frame side of the arm to correct for decreased wheelbase?
Also written above there is no decrease in wheelbase till after 4" of lift, it actually goes forward. But I would assume it would be just a small amount either way.has anyone run an offset bushing on the frame side of the arm to correct for decreased wheelbase?
This mod is popular on the other side of the pond to relocate rear mount of the rear of the front control arm.
Any recommendation on what I can do to get in spec?@FJP971 Those look spot on.
There are a few that are working on adjustable plates at this time. Infact @landtank & @NLXTACY are.Any recommendation on what I can do to get in spec?
Have OME 2.5 inch lift and replaced & corrected castors accordingly with this.
Old Man Emu Caster Correction Review
Since you have the Yellows that should of corrected 3.4 degress of the 1.7+1.75+.91=4.36 that needs to be corrected, it hard to say. I've been where you are but with 3.5" of lift. I had yellows plus the 2" MAF brackets (which worked great) now still needing more caster after I replaced with stock bushings. I'm waiting on the adjustable plate option coming soon.
I installed these after my OME 2.5" lift and I'm still -1.8 under caster spec. I need to be +2.8 degrees more to be at 3 deg. YMMV, but I'm trying to find a better solution.
Edit: After reading through this thread and the MAF site, I'm going to give them a call and probably order the control arm drop plates when I get back from my trip to Yosemite. Hopefully I can run the 2" plate in conjunction with the OME bushings to get my caster back to spec. I'll add in the sway bar drop brackets as well while I'm at it.
The truck should handle great after those...I would think anyway.
