I've been reading all of the pro's and con's of correcting caster with bushings, drop brackets, and plates, and I think for my mild lift (2.5" OME) I'd be better off with the drop brackets in the long run. I'd really like to run plates, but it seems like they're all designed for 4"+ of lift and I also don't want to have to run a DC driveshaft. The bushings might work but it seems like they don't last near as long as the OEM bushings, and they seem like a pain to install. Besides, if I change my mind later, the drop brackets come off pretty easily. Plus, if i only get the 2" drop, they shouldn't hang up too much.
So the question is, should I get the 2" drop or the 3" drop? How many degrees of caster does each inch offer?
I just got an alignment and the sheet says the left is at -1.2 degrees and the right is at -1.9 degrees. What length would get me closest to the +3 degrees?
Thanks!
Thanks!
