I just tried to put a set of 6" Delta Radius Arms on my 2.5" OME lift. As soon as I drive away, I start getting an odd and very subtle grinding when I first press the accelerator and right when I remove my foot throw the accelerator. I am wondering if the Castor correction meant for a 6" lift is putting my drive shaft at a weird angle to the pumpkin or something like that. Could be unrelated and that I need a new UJoint or something...but it started right after the Deltas. Any thoughts?
Caster correction is not a cookie cutter thing even if the products to correct it are sold that way.
You need a caster reading before any correction, lifted to whatever, stock bushings, ect.
Once you have that you can go about correcting your caster.
A 2.5” lift you are probably at 0*. But who knows really, since the axle swings in an arch and lifting rotates it forward, just get an alignment before trying to correct any caster and see what it is. It is not some set in stone thing, it varies a lot.
So let’s assume you are at 0*. Ideal caster is 3.5-4.5*, more and it will have torque steer cornering. You also will have pinion angle issues. On that note, caster correction doesn’t fix pinion angle, these are two separate issues and things to address. Fixing one generally doesn’t fix the other.
In my opinion the factory 2.5ish will make it track ok but not great. For it to track great, one finger at 80mph, you need 3.5-4.5*.
You probably have to much caster, iirc the 6” arms correct something like 7 or 8* which is a lot for 2.5” lift.
Like I say once you know your number before caster correction you can reach out to the vendors and or shop products to get you in the 3.5-4.5* range. Anything less is not ideal.
Oh you can run a DC front drive line. If your front pinion is more than a degree or so different than your front tcase output flange you will likely need one.
Cheers
