mattressking
10 digits to freedom
- Thread starter
- #261
Do you have to run spacers in the front for the 80 series steel rims?
I wanted to test fit without the spacer but didn't spend the time to pop it off prior....pure laziness. It MIGHT fit, but I think it would hit the tie rod without. I knew I should have done it for posterity sake.
35's on a 60 is the right balance for street driveability and offroad performance with and minimal mods and Cruiser axles in my opinion.. good choice
How much lift do you have again? You're going to get some rubbing issues offroad under articulation and steering but it's not too bad. I ran the same tires with blown out 2.5" springs that were pretty much stock height.
Thanks Matt! I had a lot of back and forth initially but overall it made sense and since the bfgs are undersized it was a no-brainer.
Truck initially is Light/medium OME. I put on extended shackles and AAL up front with the 'A' designation springs in the rear with one AAL removed in attempt to level the truck out. Something around 3-3.5" is my guess. I definitely see how the fronts will cause issues at lock/near lock under flex but we shall see how much interference I get while in Colorado with the flaps off.
