Builds Back in a 60 series - 1HZ Swap (5 Viewers)
Battery’s fully charged now.
C’mon fuel cut solenoid!!!
Were you going be able to stay SUA? Was curious what size exhaust you were running?
Yeah, SUA. I'm not a hardcore wheeler and the 1HZ doesn't need the added oil pan clearance.
I’m in Oregon outside emissions in the sticks so I was thinking of going straight pipe exhaust on my 4BT. With your 4BT did you have a muffler? Should I consider one?
I'd get a muffler. The drone from a diesel can really wear on you, especially on long trips. Check out the Aeroturbine 3030XL. It is a straight flow design with a built in resonator.
Thanks so the recommendation Dave
Took forever to burp the fuel lines, but she runs. It's freaking smooth too. Still chasing down some throttle issues. I probably goofed up the boost compensator install .
I also found out that the stock FJ60 radiator interferes with the fan. The lower hose outlet hits the fan blade.
Took forever to burp the fuel lines, but she runs. It's freaking smooth too. Still chasing down some throttle issues. I probably goofed up the boat compensator install .
Mine took awhile to burp as well. That’s a nice quiet motor Dave. Excellent work.
YESSSSSS!
I can't believe you got it running...30 minutes after I left.
Did you keep either fuel filter in line? What was it?
Also, it idles like BUTTAH.
It's something with the throttle and the boost compensator. I'm troubleshooting it now .
I can now start and stop it at will, just no throttle. Any ideas? @AlbertoSD what do you think? Something I goofed on when I installed the boost compensator?
