- Thread starter
- #481
Question: if I go one size up to 12mm 1.25 would I need to drill it out or just re-tap with bigger size?
Safe to say drill it first, suck to break a tap off trying to cheat itQuestion: if I go one size up to 12mm 1.25 would I need to drill it out or just re-tap with bigger size?
Or a Time-Sert, but it's a more expensive option and maybe not needed for your application. I did use one on a stripped front brake caliper, which is more critical.Helicoil if they got right size
That was my first choice. This is another instance where I'll have to shell out some $ for someone else to drill it straight and pop in a coil.Helicoil if they got right size
You might want to have someone else put a coil in all those holes, while you're there.That was my first choice. This is another instance where I'll have to shell out some $ for someone else to drill it straight and pop in a coil.
yeah I am thinking do time inserts and, do both of the shorter vertical bolt holesYou might want to have someone else put a coil in all those holes, while you're there.
It might save you another trip to the shop if you put inserts in the 4 holes that hold the carb studsyeah I am thinking do time inserts and, do both of the shorter vertical bolt holes
Hayl nawShould these be brass?
will any correct size zinc hex nuts work ?Hayl naw
Brass nuts were used back in the day as it was thought they were less prone to seizing. The choice is yours.Should these be brass?
Would any zinc plated 10 1.25 hex nuts work here?Brass nuts were used back in the day as it was thought they were less prone to seizing. The choice is yours.
Anything that'll hold torque should workWould any zinc plated 10 1.25 hex nuts work here?
Thx. Anything but brassAnything that'll hold torque should work
