99 miles to the new sty! (1 Viewer)
Question: if I go one size up to 12mm 1.25 would I need to drill it out or just re-tap with bigger size?
Safe to say drill it first, suck to break a tap off trying to cheat it
That was my first choice. This is another instance where I'll have to shell out some $ for someone else to drill it straight and pop in a coil.
You might want to have someone else put a coil in all those holes, while you're there.
yeah I am thinking do time inserts and, do both of the shorter vertical bolt holes
It might save you another trip to the shop if you put inserts in the 4 holes that hold the carb studs
Some solid work by a local machine shop. Should be good to go!
