PabloCruise
It sounds like you are making progress!Followed advice of @trainbufftony and re-tuned w/ the high idle cam off and had high hopes that this would solve my current woes and I did so albeit at a lower vac (15 in. hg) reading and still have gas from the primary. Instead of being safe w /water checking for leaks I used carb cleaner and did in fact locate a vac leak at the manifold.
Not sure if checking/ retightening the manifold bolts will help but that's what I'll do to start. Maybe should have checked the surface for being flat before reinstalling the gasket. damn it.
On my 40 when I had some crazy random issues I figured out that the carb mounting stud closest to the master cylinder had come loose!
I went to check the tightness and found that. Much better now.
