Registry 8x Series V8 Swaps (4 Viewers)
Yes it’s eBay. Seems legit. I know a few guys local to me running the same radiator. They have no complaints.
Yep, I have the same rad, 4 row , no trans cooler provisions, no heating issues! Made for the diesel.
So I am doing a L96 swap with a 6L90. After tearing the engine down I’ve decided to add a Cam. Why not right?
I will have to replace the PS pump Starter and Alternator as well. No big deal. I am curious what peeps did with the PS pumps? Will I need to get a smaller pulley. Curious about others solutions here.
from what I have researched, a cam might help with top end HP at higher RPMs, but hurts performance at lower RPMs. WranglerJKLS on YT talks about the L96 (and other LS/LT engines) and cams.
Thanks. Not worried about that. The engine is VVT. Not DOD I will have more than enough torque once done and tuned.
i made my own a/c line one to firewall goes directly to a/c compressor and front one i reused toyota metal line
and power steering i reused one toyota line and made on with one side toyota and other from GM
for transmission i used oil pan from older one and no problems with driveshaft clearance same with engine oil pan i used pan from camaro
View attachment 2167710View attachment 2167711View attachment 2167717
Hello! Can you anwer a few questions regarding your Swap? I’m getting close to finished a 6.0 LS Swap with 4L80e in my 94 land cruiser.
I used a Express Van power steering pump with remote res. I had to modify the factory bracket bc the power steering pulley is to large. What size pulley did you use? Is it ok for the power steering pump to use a smaller pulley and spin faster than normal?
I was also wondering how you connected your intake to the factory air box? Can you advise on which hoses you purchased to connect the intake to the MAF and the. The MAF to the factory air box?
I would really appreciate the info!!
Same questions. Was thinking I would have to use a diff pump.
i used engine from 2007 silverado and did not change anything on it just made two new hose one end to fit toyota steering box and other end to fit gm pump
and also i m using power steering oil cooler from ford F150
for intake pipe i do not remember what size is it but i believe it is 4" one elbow 90 degree and one 45 degree ,between 45 degree and 90 degree i just used aluminum adapter 4" to 4" and that is where i drilled hole for crank case ventilation and from MAF sensor to air box i believe it was 4" to 3 3/4 but i m not Shure you will need to measure it and on air box i cut metal flange of it co i can have round pipe to connect everything together
So does anyone know of good thread on a 2uz swap parts list? Slee did a swap and they just mention the donor engine trans and T case is from a 98 LC. The video state $25k for them to do the swap but that's not gonna happen. Thanks for any links or info.
There are a couple in the 60 series section I dont have a link tho gonna have to search. 25k to have a major buissness to do a swap that isn't cookie cutter ls swapp isn't unheard of. Not a whole lot of people even doing that swap so not much support for it.
Those of you not running the factory air filter box, what did you do for intakes?
I think I'm vapor locking / heat soaking my LM7 because of intake temps. Last night it got over 130 degrees and it stalled out on me.
My intake set up is a silicone 90 into a 4" aluminum tube to the MAF and than a cone filter all under the hood on the passenger side. The intake tube dose rest ever so slightly on the upper radiator hose.
I'm no fabricator so I can't really use the stock air cleaner box because I'm also 3 linked and the coilover tower is where the stock air box would bolt to the fender.
I'm starting to stress because I have a Rubicon trip coming up in July and really don't want to have to cancel.
It ran like a top when I finished the swap and on it's shake down run.
Then all the sudden in Moab near the end of the day it would fall on its face....
Any and all suggestions welcome! Please and Thank you!
Are you getting the heat from the exhaust manifold? Did you heat shield that guy?
also I’m curious how you did your shifter? I am still on the rebuild process in the LS so I’m a couple months from install.
@torfab makes a nice airbox. I think they're out of stock ATM though.
There's several pics up on their site.
Looks great! I ended up modifying the stock alternator/power steering bracket slightly so it would clear the steering box. It seems to work just fine as I had the vehicle running this past few days with no major issues. I did use a remote res power steering pump to help clear that power steering box in addition to the modified bracket. Now I'm working on my intake plumbing..... as you can see my stock 94 land cruiser intake lid is different than yours.... it won't work nearly as nice as the one you have (which I believe is on the 96 and 97 years?? ). I also went with a drive by wire setup and used my stock throttle cable and stock accelerator pedal... all which has seemed to work fine. I installed a 4L80e trans which I bought from my mechanic friend. Unfortunately I found out the hard way that the trans forward clutches were shot as I only had Reverse working after install!! UGH!! I have a trans shop rebuilding it as we speak and look forward to installing it and driving the truck for the first time next week!!
Whatever electric fans are those?
Any of y’all had any vapor locking issues?
How did you deal w/ them?
I have no charcoal canister anymore. The vent tube vents to atmosphere. I did add some fuel line to the vent tube so it’s not venting under the hood.
I’m running the fuel filter w/ built in regulator as well.
Vapor lock isn’t really an issue with EFI especially not with a in-tank pump
130 degree intake temps shouldn’t be an issue at all. You’ve got something else going on
130 degree intake temp isn’t stalling your engine
Vapor lock is definitely the problem.
Trying to sort it out now.
Take your gas cap off and run without it. If that doesn’t change anything you don’t have vapor lock.
  • PIP
