Registry 8x Series V8 Swaps (34 Viewers)
LS3 going in a customer's 96 80 series
LS3/4L65E/Split case
Looks right at home
The front drive assembly is made by Holley.
Yes, the split case makes the truck 4WD instead of AWD
still a lot to do, but fired up the motor last night!
I can't figure out how to load a video from my iPhone... :bang:
There's probably a better way of loading a video, but I had to first load the video to YouTube, then post a link to Mud..
dg
There's probably a better way of loading a video, but I had to first load the video to YouTube, then post a like to Mud..
dg
that seems to be the general consensus.
So, I probably over looked this but has anyone found an adapter for the temp gauge that's not from Marks? I done want to pay 35 dollars in shipping.
I know its m12x1.5 - m16x1.5 or at least that's what shows up in my search of this thread..... I'm not having much luck finding anything local. I'm probably over thinking this but figured i'd ask.
Thanks!
Thanks!
There was Auto Meter 2277 Oil Pressure Temp Metric Adapter M12 x1.5 Male to 1/8 NPT Female that would fit the LS head but I think the guy that used this had tapped the center to M16 fit the water temp sensor if I remember correctly.
I got mine off amazon for like 15 bucks.
Thanks!
I used the temp sensor in the lower manifold of a 5vzfe. It's much smaller. Keep in mind I did the resistor mod too on my temp gauge so that might change things if you don't do that.
Mocking up my trans and engine. This, right now, is my front driveshaft/oil pan clearance. I havent had much luck creating more space there. How much more room do you guys think is necessary to prevent any rubbing?
So you're going the route of tapping?
What is the resistor mod? I think I might of missed that... I have a 3FE and I think the temp sensor is the same through 97?
Yes, looking up M16 taps. I have the brass adapter.
Mocking up my trans and engine. This, right now, is my front driveshaft/oil pan clearance. I havent had much luck creating more space there. How much more room do you guys think is necessary to prevent any rubbing?View attachment 2333673
Remove your springs/shocks and lay the axle on the bumps, add some wiggle room after that. You'll probably need a smaller OD driveshaft. Any driveline shop should be able get you setup.
Here is the link. It didn't work as well as I hoped. When the needle is in the middle the temp is at 210. At 190 it's at less than 1/4 with my temp sensor.
Thanks!
just have someone cut new thread on the old sensor that is what i did , if you go that route you must use OEM sensor because aftermarket sensor body does not have enough metal to machine it to right diameter
So you cut it down to an M12? I have a brand new OEM sensor. Guess I need to find some one to cut it down.
yes you cut it down to 12 mm and i used die to cut the tread because my lathe can do only standard thread , but like i said sensor must be OEM there may be other good sensor but i do not know it looks like after market sensors r stamped v.s. OEM solid brass
was this it?
