- Thread starter
- #201
Started putting the new cams in. Gotta do valve adjustment next.
Are you aware of any LC engine or transmission or T/C issues reasonably attributable to stock S/C use?5-6 pounds. The stock pulley was 3.2 inches. I have a 3 inch pulley and I see ~6.5 pounds max.
Sooo would you guess a tranny outfit saying the factory transmission has an '87 % failure rate after installing a supercharger or turbo' is just marketingspeak? (I mean, technically, ALL transmissions fail, S/C or no, even if it's 50 years after install, but I'm guessing editorial subtleties elude them. Or maybe not...)Not that I am aware of. There never were very many out in the wild so the sample is quite a small footprint.
I'd call that garbage. I don't like how the stock auto transmission shifts, and less so with a power adder, but to say that 87% fail with a power increase sounds like someone trying to sell you something.Sooo would you guess a tranny outfit saying the factory transmission has an '87 % failure rate after installing a supercharger or turbo' is just marketingspeak? (I mean, technically, ALL transmissions fail, S/C or no, even if it's 50 years after install, but I'm guessing editorial subtleties elude them. Or maybe not...)
We are talking fractions of a percent going from tight to loose. I would shoot for right in the middle and that way you account for wear as well as things tightening up from getting hot.Finally got around to measuring the valves with the new cams in and definitely am going to have to change some clearances to dial it in. Cam grinder said it would be spot on as old cams but it wasn't. Wondering if I should just aim for the middle of the adjustment or on the looser or tighter end. If I aim for the middle I might get the valve adjustment right the first time. I know some say go wider so when the head wears it's going the right direction or go smaller end of it for max power.
Incredible work. By chance do you know where to source these torx bolts? I’m approaching this same job and I’m anticipating complete destruction of the phillips screws.When I first rebuilt the motor it seemed like I had trouble finding the Torx bit bolts for the oil pump and used Allen ones in its place. Even this was a pain to remove but probably easier than Phillips heads. This time going to go with Torx tightened to 48 inch/lbs as these don’t need much. Using new Toyota parts for the oil pump and front Crankshaft seal which I will need to hold off on until the replacement cams are installed. Speaking of, trying to hunt down a good intake cam in case Schneider strikes out finding one.View attachment 3627356View attachment 3627357
I’ve been using these. Work great.Incredible work. By chance do you know where to source these torx bolts? I’m approaching this same job and I’m anticipating complete destruction of the phillips screws.
