Builds 1997 FZJ80 to HDJ80 1HD-FTE + H152F (7 Viewers)
Told ya so...
:lol:
So a bit more about the engine: once it arrived today I asked Ian to get me pics of any numbers on the block to try to ascertain date of manufacture...
The block stiffener/bearing cap plate had “10730”= 07/30/2001
The block itself had “10803”= 08/03/2001
So, pretty far out. This has been sitting around since 2001 in a warehouse in the GCC.
Long block assemblies for service part support are only manufactured for the first 8-12 month of a new engine part number being installed into vehicles— mainly in case there is a warranty claim and an engine can quickly be swapped out. After this time period, the long block is discontinued and superseded to a head and short block assembly that then has to be “built.”
In any event, pretty damn cool historical, truly NOS beauty here. Now the research/part intensive process of “converting” this into a mechanically controlled engine vs. original -FTE configuration.
So @Onur is in full command of the parts to make this a fully complete engine. Besides what we get from GTurbo and my special requests that is. Obviously we will retain the I/C, air box, snorkel and other goodies already under the hood.
John talked to me about putting an FT in his 77-series a year ago when I worked on that truck. It was never a canceled plan he just never pulled the trigger on it until now. We talked about the new engine in the 77 but he decided to put it in the 80-series. While I really like the 77’s I think an 80 may just be slightly better, depends on if the 77 has front coils at least and is LHD. A 77-series never had either so 🤷🏼‍♂️
Cheers
Also, rear pinion angle is off by about 1.8*. I am sure it will change as all the other goodies get added but to get it fully dialed in, we decided to order some adjustable RUCA.
Rear axle is also a touch out of center in rear wheel well. I will be dialing that in as well.
Cheers
View attachment 2451504View attachment 2451509
@Onur Is this a NOS 70 series FTE or a 100 series FTE?
Nice, I wondered since the valve cover did not say "Intercooled" on it.
As I told @jmlockwood:
OH
MY
LAWD
I can’t believe it actually worked, and it was real!!!
I am holding on tight for more awesome than I can deal with.
Which GCC country was this stored? Oman?
Not sure those types of decals would be included in a replacement engine.
EPC shows a valve cover-valve cover which looks like it may have had any “EFI” or “Intercooled” decals on it?
Cheers
Here’s a little somethin’ that might be beneficial for this project...
Or does this unicorn motor just get the regular FTE sticker???
There is oil in the engine.
Wondering if it wasn’t pressure tested and the two white freeze plugs were fails?
Also appears the injectors were pressure tested with something?
Cheers
