In the last pic there is an indent on the female end. Stick a thin pick or screw driver (watch maker type) with thin shank into indent to push in tab, pull wire from other end while shank is seated.
Someone has to knowThis is the rear harness, 7 is the connectors to the main harness by starter.
What are the 2 other circled areas go to?
I know1 is the gas sending and 3 & 4 are the tail and side markers.
What is 2 go to?
Let me look... thanksWhat color are the wires? The only thing that comes to mind is the reverse light.
It's still gonna get dirty... lolIt’s too pretty.![]()
Anyone know the size?Anyone know the bolt size for the rollbar connection here?
I have looked through post and also the "boltlist" posted as well.
thanks
If it’s a seat belt bolt- it’ll be 7/16-20. Summit, Amazon, etc all sell. DOT Regulations ugh.Anyone know the size?
No , it’s the bolts connecting the toolbars together.If it’s a seat belt bolt- it’ll be 7/16-20. Summit, Amazon, etc all sell. DOT Regulations ugh.
Back on this …designed to piss you off is what this is…..I don’t see any tabs to push. Looking down the side wire is, it looks like the plastic housing is smaller than the metal connector. Is there a vid out there somewhere ??How the heck do you remove the connector on this plug? It is the side marker light plug.
Thanks
