Builds Whitey Forty - Tilda Bogue Service Station (5 Viewers)
I don’t know. Maybe I need more practice.
I need to step up my game. I should be able to do way more than this so I don’t forget how to do it.
Thanks for stepping up and pointing that out @peesalot
What brand and size 16" tires on those city racer split rims on that sweet Iron Pig? PIMP
16” Smoothie vintique with 315/75-16
I also have been eyeing those wheels.
They seem legit for the cost?
Yep, great wheels for the money. If you don’t want hubcaps they are my go to wheel
I give zero sh!T’s about hubcaps so I guess I’m G2G.
Thanks
What powder Coat Grey did you use?
**** hub caps (but they look great on your 45’s)!
Drained all the fluids out of the transmission and case. No metal fell out so that’s good. Also seems the seal between the two is good.
Front axle fully apart. No grease in that knuckle either and only 50% of the cone washers again.
I have to replace the cracked brake lines and even after a good soaking with Kroil the heads of the brake lines are snapping off. Add new brake lines to the list.
Off to get some Zepp purple to soak these knuckles overnight.
Went ahead and got the axle out of the way so I can get all this shackle reversal nonsense cut off and clean the frame or the rest of the shiny black flakey paint so we can build it back correctly next week
Nope. But I appreciate the sentiment. Lookin good in the storm trooper costume tho.
LandCruisers.
The awesome things @wngrog does to LandCruisers.
Am I mistaken that’s what this thread is about?
LandCruisers.
