There are a couple sets in the classifieds for sale.I need to locate headrest as well
Had no idea. The PO took mine off when he did the cruisercorps covers and they've been on the floor under my work bench for 4 years. Didn't know they were worth much.There are a couple sets in the classifieds for sale.
@igotta40 Any idea what the spec is for the bolt holding your seatbelt in this photo? I am missing all 4 (two on each seat). It appears to be a 12mm bolt but I can't figure out the thread pitch.
forum.ih8mud.com
Those are attached to the roll bar. In your photo they are attached to the seat. I am mainly looking for the seat bolts to stabilize the seat in the seat frame.Depending on your yr, at some point DOT required an sae bolt for seat belts You might look at post #6 in the link.
I think they're fine thread 11/16. In igotta's pic the bolt is a Grade 8 sae bolt. 6 radial markings.
77 Roll bar to tub bolts
Hello, Would anybody have quantity (6) of the roll bar to tub bolts for sale in good condition. I would like to send these out to be yellow zinc plated. The size is 10x1.25x25mm long with captive lock and flat washer with the number 6 stamped on top (or 9 if you hold 180 degrees lol... The flat...forum.ih8mud.com
@igotta40 Any idea what the spec is for the bolt holding your seatbelt in this photo? I am missing all 4 (two on each seat). It appears to be a 12mm bolt but I can't figure out the thread pitch.It’s the DOT standard for all seat belt fasteners
It’s the DOT standard for seat belt fasteners, 7/16 -20 UNF. Seatbelts plus.com has hardware sets.@igotta40 Any idea what the spec is for the bolt holding your seatbelt in this photo? I am missing all 4 (two on each seat). It appears to be a 12mm bolt but I can't figure out the thread pitch.
