So after about two + years of sitting of the fence I am starting to make provisions for a LM7 4L60E swap.
Other than taking the grill off, removing the radiator and taking out the aftermarket horn I installed last year.
I am starting into the high pressure fuel side of things. So Rusty has an auxiliary tank behind the rear axle which I will be using for the master tank. I bought a LM7 appropriate fuel pump which is ginormous by the way. Had to cut the bottom of the tank and weld on an extension sump so it would all fit. Got the box welded up and then welded onto the bottom side of tank. Got the pump loosely fit into place and pretty happy with the outcome.
Also positioned the tank into place to confirm clearances.
Also cut an access panel in the bed so the future replacement is simple(r). Going to hinge the front edge and weld in some tabs so that it rests is the same place.
