After peddling it out on the exercise bike, I spent some time wiping off the dirty stuff...
CityRacer!Replaced the coolant fluid today - thanks to this forum I picked up some great tipps in advance making the job a lot easier!!
Would anybody have a suggestion where I could get the plastic overflow tube that goes into the expansion reservoir?
View attachment 3265833View attachment 3265835
Flushing in progress!
Sorry. Typed half the response during my kid’s swim lesson and didn’t realize I’d posted it. The top was in the truck when it came from Colombia last year. Unfortunately that’s all I know.Care to share the vendor you bought it from?
Thanks!CityRacer!
OEM Coolant Overflow Hose with Cap for '78 to '87 Land Cruiser FJ40 and FJ60
This is a radiator coolant overflow hose with cap for a Toyota Land Cruiser FJ40. Fits model years 1978 - 1984.Part # 16405-60031. This is the latest iteration of the cap that appeared in the final years of FJ40 production. Perfect complement to the OEM Coolant Overflow and Windshield Washer...www.cityracerllc.com
You also may want to check into this for burping/filling radiator:CityRacer!
Interesting kit.You also may want to check into this for burping/filling radiator:
EPAuto Spill Proof Radiator Coolant Filling Funnel Kit
Amazon product ASIN B01I40ZQWE
Just make sure it’s been thoroughly burped or it will tend to overheat (or at least show it’s overheating on the instrument panel gauge) at the least opportune times. Been there, done that….Interesting kit.
I’m pretty much done by now though.
Any tipps on how to additionally burp it / get air out?Just make sure it’s been thoroughly burped or it will tend to overheat (or at least show it’s overheating on the instrument panel gauge) at the least opportune times. Been there, done that….
I always park on a slight incline with the radiator higher than the engine when I refill the cooling system. Kind of burps itself as the fill neck is at the highest point. Works every time.Any tipps on how to additionally burp it / get air out?
I thought it’s pretty much self-bleeding while running? I just keep refilling whenever I see the level dropping in the overflow canister.
Buy the kit shown in the previous post.Any tipps on how to additionally burp it / get air out?
Wish I had seen this post over the weekend. Changed out all cooling system hoses, thermostat, water pump and fan belt. Had a heck of a time getting enough coolant back into it. Tried so many things, and it definitely wanted to overheat (didn’t let it of course). In the end I took a break from it, let it sit a day, and poof….took another 1+Gal and thermostat opened. Left me scratching my head for sure!I always park on a slight incline with the radiator higher than the engine when I refill the cooling system. Kind of burps itself as the fill neck is at the highest point. Works every time.
When you squeeze the upper radiator hose - should that be full of fluid so that you cannot squeeze it anymore?With respect to burping the cooling system.
I loosen the thermosensor on the head, next to the carb. No need to remove it, just allow the air to escape and a little coolant bubble out. That and the spill proof coolant fill kit have made this task easy and straight forward. I will also gently squeeze the upper radiator hose, purging any air trapped there.
yes, it should be full. With the radiator cap removed, you should be able to squeeze it no problem. Gently though, little air bubbles will escape. Don't let the coolant level drop, you should be able to look in the radiator and see it. I was shown this method in auto shop class. Just another way to help burp the system.
