John in Utah
I put mine on an independent switch and relay ... which makes it borderline sufficient
Blew through a tank and a half of fluid on my last drive back from CO
Noted! So I guess the answer to my initial question was - Toyota used steel rivets.
I guess I didn’t think about the fact that those rivets won’t see the light of day for another 40 years or so, so I’d agree, the mixed materials/galvanic corosion is probably a moot point.
Well, that makes sense. Absolutely zero chance my FJ-40 will turn into an airplane anytime soon, so I think I'll be OK.In the aircraft world, there is no such thing as “sealed up good enough” when it comes to galvanic corrosion. Take extra care to keep moisture out
Haha, correct! 40's probably have the aerodynamics of....a UPS truck covered in tar and feathers, if I had to guess.You saying the 40 isn’t very aerodynamic?
I started prepping for my first knuckle rebuild! I scraped off several pounds of caked on dirt/grease and sprayed all the bolts with some kroil.
Question for the braintrust: I'm in a two car garage so on one side I have plenty of room but on the other I want to make sure I have enough clearnace to the wall to pull the birf/axle. Anyone know roughly how long it is?
You should be fine if the passenger side has a couple of feet at a minimum for clearance. I did mine with just two feet from the outside of the tire to the wall, once the tire was pulled it was fairly easy process. The driver side would need just a bit more room to work with, but really not all that much more. I was in a 1.5 car garage. Good luck.I started prepping for my first knuckle rebuild! I scraped off several pounds of caked on dirt/grease and sprayed all the bolts with some kroil.
nice head shot on that sow!View attachment 1871285 Drove across our saturated deer lease and hauled a few critters. See a future front axle rebuild in the near future with all the rain we've had this season.
Rolled the bones out of the shop and into the sun for a few hours so I could do front end work on my son's '03 Chevy Z71.
What kind of magic did you use to convince your son that the zero-turn mower is a Chevy Z71? I might need that recipe....Rolled the bones out of the shop and into the sun for a few hours so I could do front end work on my son's '03 Chevy Z71.
That's a good one. I was trying to come up with a wiseacre comment about the mower and swelltimes saved the day.What kind of magic did you use to convince your son that the zero-turn mower is a Chevy Z71? I might need that recipe....
My wife has a fern she keeps in the garage so it will not freeze.
I put it out in the sun every once in a while and it seams to help.
Have you noticed any new growth on the frame and engine?
Just messin with you, looks good so far.
no new growth....must not be watering it enough.....my wife said it looked like a tractor sitting out in the yard...no new growth....must not be watering it enough.....my wife said it looked like a tractor sitting out in the yard...
