What have you done to your Land Cruiser this week?
Drove back from Boise Idaho to Ketchum Idaho on this rigs maiden roadtrip voyage post engine rebuild. Has a compression issue unfortunately i'm gunna roll with, it has to do with the rings not seating properly. 700 miles in, so it was it is. The rig did great though and went 70 the whole way! maybe ill do the rings in 10000 miles or so when i feel like it.
its my first project, didn't even know how to change the oil on a car when is started. lessons learned.
Rest of the week: Chasing the burning wire smell in my dash and installing a new stereo, and diagnosing charging issue.
Rocker assembly going on this weekend. hopefully will solve valves falling out of adjustment issue (previous rocker tower had a crack in it) and help compression a bit.
Still fighting, and making music about it.
Dan
There are tricks that can be done to get rings to seat better. One is to pull long hills in almost too high of a gear, not quite lugging, but almost. Then, engine brake down the same hill in *almost too low of a gear, letting the engine slow the rig down.
I've also seen a pinch of AJAX powder or Bar Keeper's Friend cleaning powders being dropped into a spark plug hole, used as a mild abrasive which will let the ring and cylinder surface get a better seal once worn in a bit. The powder will be cycled out of the motor and will leave through the exhaust, and won't harm anything.
These are old tricks from long dead hot rodders I knew in a different life, but they've worked for me in the past.
As always, read up on it yourself before you try stuff. But it could save you some labor if it works for you. Worst case scenario, you end up pulling it apart and replacing rings anyway.
Yep, I tried the proper wheels. I tried it multile times, it would eventually birdnest b4 it went into the whip. I made sure the whip was as straight as possible. I got tied of F-ing with it.
My miller works great for whatever sized wire once the adjustments are made. It’s an older 211 but not the oldest.
Prepping the 40 and Camp trailer for a 4 days wheeling/fly fishing trip to the Serria's. We will have a total of 4 - FJ40's. 1 - FJ60 and maybe a FJ55. Its going to be a Great trip
Mines an older Miller 250.
Substitute “Gear Oil” in the morning….. “Wifey’s gonna love it!”
Whups…….
@imyahucklbrry
It does have a certain memorable quality to it...🫥
I think some require a smaller liner as well. Little hazy at the moment, but I feel like I read something about that on my Esab.
I think that's likely the issue. It's not worth changing. I'm pretty sure my liners ok. Its pretty much an industrial machine. It was lightly used when I bought it. It had the original spool on it. . The company the guy worked for bought it for him, so he could make some tooling from home.
Over the weekend I napped to watch some videos on how to contour heater hoses without kinks. I was running this effective yet ugly hose with elbows to vent the valve cover. I had some left over 3/4” heater hose and gave it a try.
Basically you bend the hose with some internal material (copper wire and smaller hose in this case), heat it to around 300° F (either in an oven or using a heat gun) then rapidly cool it in a bucket of water. My results were not a clean as the videos but with some playing around I think I could get there. Overall, pretty happy and much better than before
I like the Gates 90s as well- Gates 90* Heater Hose
Nice. I have had mixed success. That hose specifically eludes me. It still kinks after a couple days in the truck.
Major projects for me…. Did the passenger door hinge this week. By the time I lift it into position 7-8 times, I’m wasted. Had to polish the bushings a tad.. there is ZERO slop now in my doors. And I do mean zero. These @SMG door pins do a really good job over the factory pin/bushing combo
Working on panel fit before body filler and paint. Pass fender fit great, driver is off 3/8” to rear. I am thinking I should relieve fender spot welds, reposition and then reweld. I did already try to pull tub forward the 3/8“-1/2” it’s off with limited success (it’s square now). I am also ok with slotting the support but this far off it’s aligning near the flanges on fender support. Any recommendations appreciated.
Photo below of after shifting tub forward. I also used piece of steel in apron channel to align. Strap for 3rd hand help.
@Mr. Green, Do the hood 1st, align with the bib. The frt crossmember the bib bolts to is angled to adjust hood height. To adjust hood gap to cowl you may have to add shims the the frt body mount to raise the cowl. Make sure the apron mounting flanges aren't interfering with the apron and fender gap. Are the fenders stock oem or aftermarket?
