What have you done to your Land Cruiser this week?
Trailering the ol' girl, Gretchet, to get some work done out of my wheelhouse i.e. custom exhaust, electrical diagnoses etc. When she returns she might not fit in the garage with the new lift and tires. Took the top off so I can work on the new headliner in the meantime.
Th I only have few trails cleared enuff so it woudn't get trail pin stripes. It surprised me it made it up 1 trail, that usually requires a rear locker at the minimum. I attribute that to a few beers. 🍻👈🏻
FIFY 👍🏻 🫡
As the op found out, stick welding is to hot for body sheetmetal. He should be able to find a cheap 110v mig with gas. I considered one, because my miller 250 didnt like pushing 023 thru the whip. I found with the proper settings, I could get 030 to work fine.
Miller and other manufacturers sell a small push wheel for the .023 wire.
Yep, I tried the proper wheels. I tried it multile times, it would eventually birdnest b4 it went into the whip. I made sure the whip was as straight as possible. I got tied of F-ing with it.
Drove back from Boise Idaho to Ketchum Idaho on this rigs maiden roadtrip voyage post engine rebuild. Has a compression issue unfortunately i'm gunna roll with, it has to do with the rings not seating properly. 700 miles in, so it was it is. The rig did great though and went 70 the whole way! maybe ill do the rings in 10000 miles or so when i feel like it.
its my first project, didn't even know how to change the oil on a car when is started. lessons learned.
Rest of the week: Chasing the burning wire smell in my dash and installing a new stereo, and diagnosing charging issue.
Rocker assembly going on this weekend. hopefully will solve valves falling out of adjustment issue (previous rocker tower had a crack in it) and help compression a bit.
Still fighting, and making music about it.
Dan
Dan
Keep up the fight Dan. Congratulations and good job.
New exhaust manifold header pipe arrived, along with the studs & gaskets...all l have to do now is weld a new connecting plate onto the pipe & fit it when l get the time..
Also my solution to the engine turn off issue... the pull stop cable l fitted.
That header looks great. Post a video of the sound. Have you noticed a bump in power?
