1980. Thank youWhat year? That looks great.
Is this first-hand experience? In one of your rides?Just about every machine shop will check and just deck the head per the request of the customer. It's not that uncommon.
I was building what I consider my last motor for this vehicle. Rebuilt short block all new everything.Was rebuilding the head a choice? Seems young to have to.
I owned a dealership for 20+ years.Is this first-hand experience? In one of your rides?
So space the rockers up by .050, when you're building a SMALL BLOCK, it's a matter of calling the right guy with a credit card in hand.The tolerance for cylinder head warping is .0059-inch, as per factory specs. Let's say that the shop removes a bit of material, when decking the head, okay. But, decking .050-inch for compression chamber modification significantly changes the location of the rocker assembly. The maximum head refacing limit, as per FSM 2F is .008-inch. That means that you only get one chance at head-decking, or it is unnecessary as it is within specifications, as per FSM? Why not save that procedure for when it counts, a full engine rebuild? A head gasket replacement, alone, can be performed multiple times. Because iron castings are excellent in compressive strength, weak in tensile or sheer strength, as compared to steel or wrought iron, tooling used to machine it makes grain-like chips, not pasta or slinkies. The low tensile strength of the material is an issue when the tool encounters edges of the water jacket etc - corners aren't strong, like the blow-out experienced in cutting lumber. Simply changing the HG doesn't directly impose any kind of metallurgical changes, by subjecting the casting to a high-impact process of running a milling machine's fly-cutter over it, especially for those corners and surfaces where cracks begin to propagate.
I agree that .050-inch isn't something that I'd stress over, either. But, it changes things. The 2F waterjacket has this little .250-inch deep passage. If you remove .050, then you restrict the movement of coolant thru this narrow passage under the spark plug hole. Also, sticking to the book, at .008-inch decking is worth the coin, when you are not racing but instead in it for the long-haul. I'm fairly certain that the condition of the head gasket and the proper torque of the headbolts is all that is necessary, if everything else is in spec. I wouldn't pay to build a tricked-out motor. I'm in it for the long-haul, and I like lesser priced low-octane gasoline, and I respect that the gasket will yield to the headbolt torque.So space the rockers up by .050, when you're building a SMALL BLOCK, it's a matter of calling the right guy with a credit card in hand.
2fs get trickier, but I don't think I'd stress about taking .050.
Just check that the adjuster rides the valve close to center and call it good...
In my limited experience building engines, it's always worked to my advantage to deck the head and pay up for a full valve job with guides.I agree that .050-inch isn't something that I'd stress over, either. But, it changes things. The 2F waterjacket has this little .250-inch deep passage. If you remove .050, then you restrict the movement of coolant thru this narrow passage under the spark plug hole. Also, sticking to the book, at .008-inch decking is worth the coin, when you are not racing but instead in it for the long-haul. I'm fairly certain that the condition of the head gasket and the proper torque of the headbolts is all that is necessary, if everything else is in spec. I wouldn't pay to build a tricked-out motor. I'm in it for the long-haul, and I like lesser priced low-octane gasoline, and I respect that the gasket will yield to the headbolt torque.
Legit, this gives me all the feelsInstalled the PTO winch and rolled up 165' of 5/16" wire rope with original chain and hook.
But, what shop is going to just deck a head? Do they stand by their work if there are further issues? The head also needs to be cleaned, as the milling process can introduce metal chips into the water jacket. It needs magnifluxing, if the cast iron has yielded anywhere to pressure and thermal exposure. If the head is no longer flat, maybe the block is also no longer flat. Maybe the block and head conformed to each other, that is why they are warped, and bringing the head back to a plane will actually create a mismatch that wasn't there before it was decked? If the head needs resurfacing, maybe the valve seats are no longer round, due to warping. If the valves leak, how can a compression test be used to check the fresh seal on the headgasket? How will the piston rings be properly lubricated, when the cylinder hone is all gone in places; I see obvious deficits in the cylinder walls of that 250 straight-6? The engine builder fixes leaks, both obvious and sub-clincal. I watch the Dave's Auto Center on YouTube, and he always says that customers just want him to replace a piston, or whatever, but every time it is a full rebuild.
@hanzo111 I would love to see more of that 250. I'm intrigued by the tech, and I once had a 250 in a '79 Nova.
Pretty cool seeing this think work for the first times after the rebuild after setting in a field since 1974!!! Thanks to MUD, I was able to slowly find all the parts to make it work on my 1980 model.Installed the PTO winch and rolled up 165' of 5/16" wire rope with original chain and hook.
When I put that thing in gear and it started spinning the drum, I was like a kid Christmas morning!!! Very coolLegit, this gives me all the feels
.. Have a good weekend...
Wow! Glad it's getting used!Sent @tugcapt1 ’s Blueberry out west out for the winter.
@White Stripe you might recognize the 3/4 tub.
She’ll be enjoying the dry desert air where every 40 should never have to leave.The “Berry” was like the shop cat…What now?
