What have you done to your 100 Series this week? (35 Viewers)
That is an awesome price! Only problem with PC is you can't do the plastic center caps.
I had them wet paint my centers to match the powder.
New shoes and some color!
Blues Sea fuse block mount. I picked up an aluminum sign from the scrap yard to make this. I added the 100A breaker for extra security and to make it switchable. There is room for 3 relays but I only need 2, but there is room. I wanted constant power to this fuse block so it is directly connected to the battery. A few weeks ago I had installed the slee battery upgrade tray.
[/URL][/IMG]
[/URL][/IMG]
[/URL][/IMG][/URL][/IMG]http://s1149.photobucket.com/user/rmckeown/media/image_zps596798e2.jpg.html
Nice! I love Blue Sea electrical equipment.
I ordered a 4 gal rotopax gas can and two 2 gallon water cans with mounts to put onto my rack. Now I need to get off my butt and put my new non ahc rear springs and gasket in.
Replaced fuel filter.
Now planning next mod - finish sound insulation or start second battery?
Got all of the components to build my Ram iPad mount:
And a bag of chips, as the saying goes!
Do you get much bounce with the dual cups? I run a single cup but use an articulated arm (3" + 8") with a furniture pad on the 8" to allow it to rest on the dash for stability.
Destroyed the rear drive shaft...
Do you have anger issues? :)
Trying to install a slee diff drop and the control arm bolt won't budge. If I use heat can I reuse the bolt and nut? I've used pbblaster.
Looks great. Are you considering a cover for it or is your setup ok with water?
This weeks repair list:
Drive shaft (bent)
Motor and t case mount (broken)
Lower Control Arm (about to fail).
It was a good weekend!
Rebuilt Master Cylinder
Been noticing my brake pedal sticking lately on my '04 LC. From reading other threads, I expected the worst so I took her in to my favorite shop for an oil change and asked them to take a look. They had added fluid replacement to the recommended list of maintenance items anyway.
Well, my worst fears were real - the MC was toast and the seals were all screwed up. He also said that the brake fluid had a weird smell and he wasn't even sure it was brake fluid. :mad:
Fortunately, they were able to go the rebuild route $60 vs. $2400. All is well.
2 new car seats... Woot!
