I don't regret moving up to 35s, but I regret doing it *without* addressing the gearing ratio at the same time. Savings towards an underdrive and low-gear reduction modification to the t-case to solve.
I also regret buying cheap lights (since replaced by costlier but much better ones).
I feel exactly the same way with my Victory4x4 roof rack. The cross bars sit way too low on the side rails and you HAVE to buy their own mounts to mount anything. I wanted the option to easily remove my awning and water supply off the rack when not in use, like the Ironman or prinsu quick detach, but they're just not compatible. How much money I've lost with the 20% restock fees...
I have plenty of bars, too many. My rack is over 110#, I way overbuilt it. Trying to solve that now but these companies aren't making it very easy.
Rant: Most of these company's websites are just useless.
Ex.
Prinsu: The images aren't big enough or high resolution enough to see any details about the rack. How tall is that lip on the side rails? How exactly does it mount? What's the gap between the side rails and roof? Hell, on the same page it tells me the rack weighs "less than 55 lbs" and also "the rack weights 63 lbs", um, which is it? And they don't even bother listing the dimensions. Basic stuff, just incoherent or omitted entirely.
Prospeed: The images are basically thumbnails, I can't see anything about the rack in them, as most are of installed examples at super low resolution. There's only one pic of the rack assembled without a bunch of stuff on top of it, but it's so resolution I can't tell if the bars are stationary or adjustable. I can't even see if there are pre cut slots or how many. Says it's the "lightest on the market" but doesn't bother listing it's actual weight. 0 dimensions listed. How do you not list a weight or size for a roof rack? It's baffling.
Victory: Credit where it's due. I can zoom into high res pictures, they list dimensions, they list a weight.
Front Runner: Click to zoom into the pics and they turn into a blurry mess. But at least they give complete specs.
I've been pretty happy with my Prinsu. Mine doesn't have a significant lip from the side rail that sticks up past the cross bars. There is not much gap between the side rail and roof, but it mounts (IIRC) to 3 of the 4 sets of factory roof rack mounts. There's not a ton of clearance to secure brackets, but thankfully I have a gantry crane now with a chain hoist. I have 9 cross bars, my RTT is secured to 4 of them. To get the tent on/off (now that it's all bolted down) is pretty simple, as I just unbolt the 4 cross bars and then lift the tent fully off leaving every other cross bar in place. Getting it back on is equally easy as I just lower it into place and then bolt the cross bars back in.
Can't speak directly to weight, it's lighter than I thought it would be, but we basically assembled it on the vehicle by loosely bolting the side rails down, securing the cross bars, then going back and tightening all the bolts for the side rails.
Also, if you just open the installation guide that's linked on the product page there are a lot more detailed pics. I imagine that the weight is also largely dependent on whether you install every cross bar, wind deflector, light bar, etc that would be considered part of "the rack"... and the weight discrepancy referenced could be difference between rack weight and shipping weight.
I purchased a set of RAD Rubber engine splash guards, which are really no better than the OEM splash guards, aside from being slightly thicker. I had expected them to provide better protection, but that was not the case. My original splash guards were still in very good condition, so I reinstalled them.
As a Canadian, I ended up losing money when I sold the RAD Rubber splash guards to a fellow Cruiserhead in the United States due to shipping costs and the exchange rate.
I was also disappointed with the roof rack mounts sold by Trail Tailor. One of them did not withstand my trip on the Trans-Taiga Road. With my Alucab RTT, the road conditions were simply too harsh.
The top part mount failed when I was approximately 250 miles from the nearest town. Fortunately, there was an outfitter 25 miles aways (the only one) where a kind gentleman welded it back together so I could complete my trip. After returning home, I replaced the mounts with custom 3/8-inch steel brackets that were cut and bent by a local fabrication shop. Despite this experience, I have purchased other products from Trail Tailor and have been entirely satisfied with them.
